Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Current Buffer for I-pod
Old 18th February 2006, 06:01 PM   #1
erictoucan is offline erictoucan  Hong Kong
Send a message via ICQ to erictoucan Send a message via AIM to erictoucan Send a message via MSN to erictoucan Send a message via Yahoo to erictoucan
Default Current Buffer for I-pod
If anybody know how to use the power in fire wire of the I-pod to power a dual JFet or supermatch pair LM194 as current buffer for I-pod. I find the higher acoustic of I-pod output is still far from ideal. If we can make use of 2n5912 or LM194 that should be good
chung
Old 3rd March 2006, 07:58 PM   #2
cetoole is offline cetoole  United States
There are plenty of headphone amp designs out there, several of which are portable. Since you are talking about using it with an ipod, I would imagine size and portability would be a major concern to you, as would battery life. It would probably make some sense to go with a battery powered opamp design for a portable amp, as using power from the ipod will be quite low voltage, and reduce the already not so great battery life. Check out some of the following pages, some have pcbs that you can buy now, some are working towards that, some you are on your own to get boards for, but it can be done, and some are done on protoboard.
http://www.tangentsoft.net/audio/mint/
http://www.tangentsoft.net/audio/cmoy-tutorial/
http://headwize.com/ubb/showpage.php?fnum=3&tid=5806
http://headwize.com/ubb/showpage.php?fnum=3&tid=6096
Old 4th March 2006, 09:25 AM   #3
lgreen is offline lgreen  United States
lgreen's Avatar
Or you can use a DRV134 like I did.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Current Buffer for I-podHide this!Advertise here!
Anyone played around with this HA-5002 current buffer? georgehifi Digital Source 2 10th June 2008 02:45 AM
current buffer for cd output maxpou Digital Source 0 14th February 2008 05:14 PM
THAT2180 used as current buffer / in IV stage? ash_dac Digital Source 0 29th May 2006 01:49 PM
kind suggestion for an high current buffer. beppe61 Solid State 11 15th October 2005 07:36 PM
Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? sardonx Chip Amps 18 19th March 2005 01:23 PM
Copyright ©1999-2017 diyAudio
