Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th October 2006, 09:31 PM   #201
anatech is offline anatech  Canada
anatech's Avatar
Hi Dave,
How were those cables terminated for your test?
-Chris
Old 14th October 2006, 09:35 PM   #202
frugal-phile(tm)
planet10's Avatar
Originally posted by anatech
Hi Dave,
-Chris
Not my test... one of the local guys at Shaw cable (& measured using some of their test kit)... the web page is fairly explicit as to how the test was conducted.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th October 2006, 10:04 PM   #203
Panicos K's Avatar
As I said to Johan,my english is not as good as yours so can SY,poobah and burnedfingers explain to me the joke with the Heisenberg uncertainty principle and Heisenberg's dog please?
Old 14th October 2006, 10:26 PM   #204
phn is offline phn  Sweden
phn's Avatar
I think Poobah summarized it best: "The problem with the uncertainty principle is that it's only correct if and only if you don't understand it..."
Heisenberg and Bohr would insist the cable only exists when being measured.
"The concept of the path of an electron between two successive measurements is meaningless."-- Heisenberg
I'm sure Poobah and Co have more to add.
Old 14th October 2006, 10:29 PM   #205
SY's Avatar
Terminated with 0.22 ohm. That's designed to show up differences which are insignificant with real-world loads. If you made the load a speaker, those curves would overlay each other pretty closely. The differences due to L and C show the most effect in the top octave where spekaer impedances are generally rising. No info was given about a crucial variable, the way the cable was laid out (i.e., loop or straight line).
PK, my bad joke was in reference to Schroedinger's Cat, a famous "paradox" that really isn't, with a reference to controversies in early quantum theory between Heisenberg (matrix methods) and Schroedinger (diffusion equation). The target is the silly stuff that the cable peddlers throw out there to explain why their bazillion dollar cables work so much better than cheap stuff despite no-one being able to hear the differences in any sort of controlled testing.
It really is just R, C, and L. Magic is fun to believe in but must be left to the imaginations of our children for us to be allowed to concentrate our efforts in useful areas.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th October 2006, 10:48 PM   #206
Panicos K,
No, no, no! No offence taken by me or given by you! To be "saddened" simply meant that I thought I explained (in this case) universal principles, not my particular opinion, and that I was perhaps not successful. It could also have to do with my perhaps inadequate explanation. Anyway, your post is most welcome, and do not bother about the language - I cannot speak yours at all!
Planet 10,
I am not here to criticise or above all to knitpick (heavens forbid!) But the neat graphs given by you and the explanation in the original script can serve as an example to illustrate.
Firstly, for the reasons given (if I understand correctly) the author used 0,22 ohm as a load. Make the load small enough and, if the generator can cope, at some time any cable will present a counting series impedance. But calculating back, I found the inductance that gave rise to the shown increased series impedance (blue trace) to be about 1,8 uH. That is nothing abnormal for loudspeaker cables, and in an 8 ohm system will not matter until well into the hundreds of KHz, if not MHz. (I did not see a generator impedance; it could not have been zero.) Similar re phase shift; our speakers are not 0,22 ohm.
Furthermore characteristics at 100 MHz is mentioned, where cable length and characteristic impedance comes in - what is remotely the relevance to audio? Etc. - I do not want to dominate the thread.
Regards!
Old 14th October 2006, 11:17 PM   #207
poobah is offline poobah  United States
poobah's Avatar
SY,
Wasn't it ultimately decided that Shrodinger's cat was a mess of sillyness? Wasn't the resolution in having many cats in many boxes and finding half of them dead?
Old 14th October 2006, 11:19 PM   #208
SY's Avatar
The better resolution is understanding that even with an inanimate particle counter, the quantum state collapses since a measurement has occured. No human intervention is needed.
Old 14th October 2006, 11:22 PM   #209
jackinnj's Avatar
I still think that the orange speaker cables from Home Depot are the best -- particularly for Class D.
Old 14th October 2006, 11:41 PM   #210
poobah's Avatar
To paraphrase Steven Hawking, "When people bring up Shrodinger's Cat, I reach for my gun".
Page generated in 0.11647 seconds (74.30% PHP - 25.70% MySQL) with 11 queries
