Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 31st January 2006, 12:53 AM   #1
Qub is offline Qub  Romania
Arrow 5.1 audio system for PC
Does anyone know how to build a 5.1 audio system for PC, i have a 5.1 soundcard and only 2 speakers and i would like to have a 5.1 system.
Please help me if you can.
Thanks in advance.
Old 31st January 2006, 08:35 AM   #2
I'm listening.
regards Andrew T.
Old 1st February 2006, 11:33 PM   #3
Bungle is offline Bungle  United Kingdom
I built a unit for 5.1. It has six opamp preamps with indervidual gain controls feeding into a 6 gang volume pot feeding into 6 TDA2050 25W chip amps and six speakers. It has a +/- 25V 3A regulated psu with over current and dual voltage tracking based on Sir Clive Sinclair's design for the old 1970's Z60 amp modules.
It has audio and video inputs for DVD player, PC, Video and an aux selected by relays, the video is routed out to the tv.
It needs large heatsinks which I salvaged out of old Norstar Phone systems. It turned into a bit of a monster to build.
If you just want a unit for the PC you only need the six power amps using the analogue outputs and you can use the volume controls in the PC software. If you have digital o/p only you will need a decoder in which case you may be better of buying a unit.
I just used TDA2050 circuits in the application notes at ww.st.com
25Watts per channel is a bit of an overkill so suggest you use a lower power ic's
Old 2nd February 2006, 05:57 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
Thank uncle Rod.
http://sound.westhost.com/project73.htm
What audio system do you have? hugobross Everything Else 70 1st November 2010 08:56 PM
My Audio System (for the time being...) victoriobenatti Multi-Way 1 18th June 2008 01:04 AM
Detachable car audio system. v-bro Car Audio 5 9th January 2007 11:32 PM
car audio system needs help stephen22 Class D 14 13th March 2006 07:32 AM
System Audio 1270s Positron Multi-Way 0 15th June 2003 12:50 AM
Page generated in 0.07840 seconds (65.51% PHP - 34.49% MySQL) with 10 queries
