Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th January 2006, 04:38 AM   #1
Default World's most problematic FM Transmitter...
Hi everyone,
i hav attached a 1WATT Mono FM transmitter Schematic with this post. I have tried it on a breadboard and had also ordered for its PCB.
After connecting a 75 cm aerial, the DC power consumed by it is around 80-100 mW. Range is at max. about 10-15 meters. The tall claim of 1km range with 1WATT power o/p seems to like a man counting for no. of coconuts in a huge coconut tree from ground level.
The freq stability tops it all. I switch on the transmitter with the default freq tuned at 102.5 Mhz. After 5 mins i hear the audio in my receiver at 103.6 mhz ..!! I restart me transmitter, and now the freq is around 101.8 mhz and also hear the same reception at frequenies of 97 Mhz, 100 Mhz, 106 Mhz, 89.5 Mhz..............................
Your obvious answer would be try for another FM Tx kit and wish me best of luck for that. But if anyone points out the drawbacks of this ckt would be nice. So guys, here's the rough pic of the schematic.
Thnx.
________________________
Old 16th January 2006, 02:09 PM   #2
I_Forgot's Avatar
What is wrong with that circuit is that it has nothing to give it a stable output frequency. If you move your hand near it, it will shift.
If you want the thing to be tuneable and stable, you need a circuit that uses a PLL IC with a crystal reference to set and maintain a constant frequency.
There are a lot of FM transmitters being sold as accessories to mp3 players these days. I would look at modifying one of those.
I_F
Old 16th January 2006, 02:28 PM   #3
If it is put into a metal case, the ambient temperature is fairly stable and and the supply voltage is constant as well then it should be accurate enough for a TX of this kind.
What I don't understand is the reason why Q2 is connected the way it is. More logical would be an emitter follower or common-base.
Charles
Old 16th January 2006, 03:37 PM   #4
The circuit is drawn incorrectly, Q2 (a 2SC2570) is NPN (not PNP), so the collector should go to the coil at the top, and the emitter is the input from the oscillator stage. The stage is, of course, operating in common base.
Assuming he's not got his PCB yet?, I'm not suprised it's not working well - you can't build VHF circuits on bread-board, the massive stray capacitance will completely ruin the circuit.
Nigel Goodwin
Old 16th January 2006, 03:44 PM   #5
Q2 as common-base sounds logical. Maybe it should be biased as also.
For the output stage class C is O.K. but for the buffer I am not sure.
I built more than one quite similar TX using breadboard and they all worked O.K.
Charles
Old 16th January 2006, 03:50 PM   #6
moamps is offline moamps  Croatia
With 22ohms base resistor?
It's CE in class C, IMO.
Old 16th January 2006, 03:56 PM   #7
Definitely common base in class C (if connected like mentioned by Nigel) !
Charles
Old 16th January 2006, 04:44 PM   #8
Yes, it could be drawn completely wrong, and be common emitter instead?.
Nigel Goodwin
Old 19th January 2006, 09:29 AM   #9
I_F
Hey can provide me some links from where, i could find a PLL FM Transmitter tuneable in 88-108 Mhz..?? The power o/p in the range 500mw - 1W, should be ideal for me to build.
Thnx in advance.
Old 19th January 2006, 09:40 AM   #10
lineup is offline lineup  Sweden
lineup's Avatar
Harry's Homebrew
is a nice site with small easy build FM circuits and schematics
It is a wellknow site.
In this page, if you scroll a bit down to
Schematics of Transmitters, Oscillators, RF Amplifiers :
you find many links
Links for FM Transmitter Kits, Circuits, Electronics ...
Here is a nice FM circuit using crystal and transistors
with 250-800 mW output
http://geocities.com/ajpotts19/vhfnbfmtx.html
Even if I guess some (old) members here at diyaudio are good at Radio Freqency Circuits
I am afraid you will not find many topics about it
lineup
FM transmitter / PA Studio1 Tubes / Valves 4 17th July 2008 12:25 PM
another problematic question SunRa Full Range 12 18th September 2006 08:04 PM
FM transmitter kamathajit2002 Digital Source 2 3rd January 2006 05:01 PM
Page generated in 0.15012 seconds (64.25% PHP - 35.75% MySQL) with 11 queries
