Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 30th January 2001, 05:44 PM   #1
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Does anyone use or have any idea if computer UPSs are useful for audio mains conditioning and filtering? For example, using a UPS as you would a power conditioner from Tice or Wedge? If so, what would be a good VA rating to use. What brand, if any, would you recommend. I've seen UPS w/ 500VA ratings going for $80.
Old 30th January 2001, 07:00 PM   #2
I don't think so.
As I understand UPS's they are just a relay connected to the power and a battery (esentially). As long as there is AC power, it should act like a plain wire.
pixie
Old 31st January 2001, 02:25 AM   #3
FYC is offline FYC  Hong Kong
I once noted people trying to use UPS fully charged and then unplugged from wall to drive phono amp, pre-amp or DAC. The capacity should be sufficient to run these for hours. Result claimed to be very good.
Old 31st January 2001, 01:17 PM   #4
Schaef is offline Schaef  United States
Smile If I remember correctly....
If I remember correctly, the good UPSes are constantly running off the battery and letting the AC charge the batteries as long as there's power. So, the conditioning of a constant AC voltage is there, no dips or things like that. The problem is, and this is where things get fuzzy for me, in the shape of the AC waveform. in order to convert the DC of the batteries into AC, they approximate the AC waveform in steps, and its these steps that can cause problems. The waveform may be more consistent, but it can contain quite a bit more noise than before.
If you really want some clean power, why not figure out a way of eliminating the AC-DC-AC-DC conversions involved and run straight off the DC of the batteries. (If I understand the amp designs, they run off DC anyway) So the short answer is, maybe you'll get some better power, it depends on how bad your source is to begin with.
P.S. - Keep in mind, I'm not an electrical engineer, I'm a computer geek who's dangerous with a soldering iron.
Old 31st January 2001, 01:59 PM   #5
Eric is offline Eric  United States
Eric's Avatar
Exclamation Different Waveforms
The waveform coming from a UPS is often not a regular sine wave, but a square one. I've heard of this causing difficulties, although its been so long I don't remember the exact source of the criticism. While not exactly scientific, my monitor behaves strangely when powered by only the UPS, not the AC power cord. Buzzes, hums, and strange squiggles on the screen - these effects are minor, but indicate something a little strange going on...
Old 31st January 2001, 04:27 PM   #6
vdi_nenna's Avatar
Ok, seems like their are more vote for not using one.
Then my next question would be which line conditioning systems for audio purposes is a good value? I think Monster Cable makes one now for around $250. Can anyone recomment any others?
Thanks,
Vince
Old 31st January 2001, 04:48 PM   #7
Eric's Avatar
Lightbulb Power Conditioners
I use one by Panamax mostly for surge protection. There is a little "conditioning" built into it, but not much... From what I understand, some of the better ones come from companies like 1) Tice and 2) Power Wedge. Each offer models with digital & analog isolation, dedicated outlets for high powered amps, etc. Entry level into these products is a little pricey - perhaps $200-300 for base models. Check out Audio Advisor for some descriptions and products. I believe they carry both Tice & Power Wedge.
Old 1st February 2001, 08:06 PM   #8
Default why?
Isn't this why we spent hundreds of dollars on filter caps and high frequency bypass caps? Isn't it true that our oversize transformers and filter caps act like huge resovours that will not charge or drain quickly in response to mains ripples thus filtering out all but a sustained change in voltage, which would result in a gain or loss in max power but not distortion? Would not the bypass caps on the amp boards filter out the rf noise? Am I over simplifying things or have I made a legitimate case?
Old 1st February 2001, 10:11 PM   #9
vdi_nenna's Avatar
Default UPSs
Well...the reason to use a line conditioner is to do just that, condition the power coming into the house. If you were able to see the wave form of a power outlets 50-60hz wave, it's very dirty. What the conditioner does, aside for cleaning up pops and RF, EMI and other interference is provide a clean AC wave form. Raising the voltage when there is a sag or lowering it if there is a surge. A power amp supply usually can't do this. (But somewhere there probably is one built by some krazy DIYer.) Line voltages don't stay at a nice 117-120 volts all the time.
I believe that the sound of your system starts to be effected even before the power cord.
So.. back to my original question. Can a UPS do this? From what the forum says, it's a big fat NO! A square wave is not like a Sine wave. That was all the answer I needed.
I did find one from Tripp-Lite that was inexpensive, but had only 4 outlets. But, I'm trying to make sure it is able to be used for Audio/Video apps. It goes for $80. Hopefully their info people will get back to me. If it does work, I will share it with you all.
[Edited by vdi_nenna on 02-01-2001 at 05:14 PM]
Old 7th February 2001, 11:17 PM   #10
promitheus's Avatar
A UPS is a bad idea for audio use.
Unless it is pure sine wave, which I doubt. (99% of commercial UPSīs are not). If it is not 100% sine wave then it generates a lot of harmonics into your system which is worse then using the original mains.
A better idea is to use mains filters and a mains stabiliser.
The filters,that should be rated at high currents, take out the noise from your mains supply. So RFI doesnt get into your audio equipment.
These filters are low pass filters and are connected between the mains outlet of your house and the power plug of your equipment. The are designs for this, but even easier is to buy a ready one usually in a metal enclosure with solder tabs or with flat connector tabs.
The stabiliser keeps the mains voltage constant. Either if that is 117 Vac, 230, etc. They are usually a transformer (which also acts as a mains isolator) with multiple primary taps. For instance 200, 205, 210, 215, 220, 225, 230 etc. and secondary at 220, for Europe that is. These usually monitor the mains voltage and accordingly change the primary tap so the output is allways the same.
Page generated in 0.15011 seconds (65.81% PHP - 34.19% MySQL) with 9 queries
Copyright Đ1999-2012 diyAudio
