Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 2nd January 2006, 03:12 PM   #11
Warp Engineer
On Holiday
AudioFreak's Avatar
Originally posted by MaXiZ
is this an "ok" schematic?
http://www.mitedu.freeserve.co.uk/Ci...er/1230psu.htm
For providing power, that circuit should probably be adequate even if not ideal. The whole point though is that you absolutely need the circuits that handle 5VSB, PS_ON and PWR_OK or you will never even be able to start the computer (and jerry-rigging those pins to "trick" the motherboard isn't really an acceptable solution).
- Dan
Old 2nd January 2006, 03:53 PM   #12
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
What's 5vsb exactly?
Old 2nd January 2006, 04:12 PM   #13
Warp Engineer
On Holiday
AudioFreak's Avatar
5VSB is the 5V line that appears on it's own pin on the ATX connector. The 5VSB line has +5V on it at all times when the power supply is plugged into the wall even if the computer is turned off.
Jerry-rigging. I mean you actually need the logic to handle this not just to jumper these lines to the voltages the motherboard would expect when things are ok.
- Dan
Old 2nd January 2006, 04:43 PM   #14
MaXiZ's Avatar
I'll make some experiments.
At max i'll lose a cup+motherboard with a volue of 20€!
Why not? If i supply EXACTLY +12.00V,+5,00V and +3,3V at right current...
Old 3rd January 2006, 05:14 AM   #15
Warp Engineer
On Holiday
AudioFreak's Avatar
I think you need to read the official ATX12V 2.2 specs all the way through a couple of times so you can fully understand what those control lines do and the logic required for them.
http://www.formfactors.org/developer...public_br2.pdf
- Dan
Old 3rd January 2006, 08:02 AM   #16
AndrewT is online now AndrewT  Scotland
Hi AudioF,
thanks for the ATX pdf.
regards Andrew T.
Name this Connector thermionic Parts 7 16th July 2009 03:31 PM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
ID PCB connector for me please? markiemrboo Chip Amps 3 11th November 2006 12:19 PM
F-connector vs. BNC pooge Digital Source 6 2nd August 2006 08:53 PM
AC connector alizawi Chip Amps 10 4th April 2006 02:43 AM
Page generated in 0.11612 seconds (65.06% PHP - 34.94% MySQL) with 10 queries
