| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
MY atv only puts out 12-14v at high rpm at around 2 or 3 amps, is there a way I could up the amp output without changing the stator/magneto assembly, I want to run a pair of 55w halogen lights off of it, im considering a battery but that wil add weight.
#2 |
What's an ATV?
A bigger alternator is the only way to get more current...
Al The miracle is not to fly in the air, or to walk on the water; but to walk on the earth. Chinese Proverb |
#3 |
ATV= all terrain vehicle... Like a '4wheeler'
![]() Adding/upgrading the battery might be one solution,if you don't plan on running the lights continously,or for long times..They'll eventually drain the battery,and it will take a while for it to recharge from the ATV.. Getting a larger magneto/alternator setup would be the best bet. Or finding some bright lights that use less power? |
#4 |
Oh, one of those Honda type things!
Obvious really! Those discharge lamps seen on high end cars are supposed to be more efficient, that might be one, (expensive), route you could take.
#5 |
LEDs are another way to go
| Thread Tools | |
| help with possible lighting mod | YonjaminYodle | Everything Else | 1 | 16th June 2004 10:17 PM |
| Page generated in 0.22426200 seconds (37.97% PHP - 62.03% MySQL) with 10 queries |
