| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Here my design for my passive pre-amplifier. It does have two active crossovers in it to make a high pass for the TB's and a low pass for subwoofer. I also threw in a volume control, source selector, and gain controls for each channel of the high pass, and one for the low pass. Those are important because I do not plan on a volume control on my amplifier, just an on and off switch. I might take out the subwoofer gain as the plate amplifier has one, but it would be convenient to have one on hand and not under the desk.
I currently have the TB W3-871's, which I plan to switch over to John "Zaph" Krutke's box 3 design with notch filter. The subwoofer will be a TB W6-1139SG ported to 34 Hz, in a .5 cubic foot box. Dimensions are, 10.6 W, 15.4 H, 7.8 D, with 1 inch diameter port by three inches long, Powered by a Dayton 25wRMS plate amplifier. It gives a nice flat output, and has -3db roll off at 30 Hz. Not bad for a 6.5 inch woofer huh? The Hagerman bugle may come a bit later.... I plan to have a separate power supply from the bugle itself because of the design of the bugle. I can also run it on 9v batteries if I need too. The crossovers and power supply are made by Marchand Electronics Inc. They are kits, as well as the amplifier by Tubes and More. Chassis choices are undetermined. ![]() ![]() Sorry about the sideway image, photobucket would not take it horizontally, at least at a decent size. |
#2 |
Why the hell does no one have any input? I can not even begin to see why this holds zero interest in any way, but other topics can go on for days about silly things.
#3 | |
Otherwise 25wRMS to subwoofer and 2x8wRMS is a good level of power. 95% of people wouldnt ever need more. ( Discotechque Owners excluded ) The Tagband TB W3-871 are good speakers. There are probably many around here that can give hints on using them. I would most probably be happy with yout setup. What I have understood Bugle is an affordable Phono amp with very good quality.
lineup |
#4 |
Yes the Dayton is a transistor amplifier. http://www.partsexpress.com carries the Dayton lines. Plate as in made to attach to a subwoofer box.
The Bugle is "so affordable" you can choose to use 9v batteries instead of a power supply, but only get around sixteen hours of playback I believe. http://www.hagtech.com/ I plan to incorperate the power supply, but perhaps not right away. Another thought is the power supply from my preamplifier could power this I think.... I would just have to make some sort of power supply connection jack on both. This would however make the Bugle pretty much inserparable from the preamp. Perhaps I should just throw the Bugle into the preamplifier? |
| Page generated in 0.08396 seconds (74.58% PHP - 25.42% MySQL) with 9 queries |
