| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Good Day,
Can anyone help me with the following, 1) Suppose an amplifier is rated 100 Watts RMS into eight ohms, how do I calculated the power output from the amplifier if it is connected to a four ohm load? 2) Total Harmonic Distortion and Intermodulation Distortion is most often given in a relative value, i.e. a percentage(%). One operational amplifier that I know of says it has THD less than -120dB. How do I convert THD from a dB value to a percentage value(%)? Thank you. |
#2 |
1) Crank the amp, drop a 4 ohm power resistor in a thermos of water, and see how long it takes it to heat the water? First empirical method I thought of. Not necessarily wise. If the amp is not current limited it will be close to 200 watts.
Be sure your foil hat has a good low impedance ground. |
#3 |
2) dB are logarithmic, -3dB is half, -10 dB is one tenth. So -10dB is 10% and -20dB is 1% and -120dB is not much.
#4 | |
For an amplifier with a stiff power supply and hefty output devices, almost double the output power will be put into a halved load. Note: modern consumer-grade stuff will not necessarily have either of those things. More likely, it will either clip excessively (and sound like poop ) at lower volume setting, or else it will just blow up (really! )
Jesus loves you. |
#5 | |
10 Log (1/100) = -20 dB. So 1% THD = -20 dB. 10 Log (1/1,000,000) = -60 dB So .0001% = -60 dB 10 Log (1/1,000,000,000,000) = -120 dB. So .0000000001% = -120 dB. Put another way, -120 dB is is one trillionth of the total, or one ten billionth of a percent of the total.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#6 |
C'mon guys..... GEEZE!!!!!!!!!!!!!!!!!!
Back away from the eggnog - If you're talking about voltage or current, the formula is: Gain = 10 to the (dB/20) power = 10^(dB/20) = inv log (dB/20) If you're talking about power, the formula is: Gain = 10 to the (dB/10) power = 10^(dB/10) = inv log (dB/10) If you want to find db from a gain, for voltage or current, the formula is: db = 20 log (Gain) For power: db = 10 log (Gain) So for -120 dB: Gain = 10 ^ (-120/20) = 0.000001 times 100 to get percent = 0.0001% All log are base 10... don't use "ln"... that is base e (natural log) |
#7 | |
should teoretically give 200 Watts in 4 Ohms. If only the voltage supply sets the limit. It is how high the voltage is over a resistor that sets how much power. A voltage supply to an amplifier is fixed to what transformer can give. now power is BOTH current and voltage. If the trafo->power supply can not deliver enough current to reach same voltage over 4 Ohm as over 8 Ohm than will not be twice as much power, if we half the Ohm, impedance. The more current we try to take from a transformer the lower the voltage will be, unless the transformer is rated to deliver this current. Transformers are rated for example 2x30 V, 10 A = 2x30x10= 600 VA VA. V for Voltage, A for Ampere But not only transformer and power supply can limit max power. Also the output transistors have to be able to transfer current. Transistors have ratings for example: 20 A peak - what can be delivered for a very short time 10 A average - what can be delivered for infinite long time without transistor burns and destroys. To know what power is output you need to know true impedance of you loudspeaker or use a power resistor of 4 Ohm. Then you measure the AC-voltage across load. Should be a good AC-meter, that can measure audio frequencies. Most multimeters are for measuring 50 Hz/60 Hz and are no good much above 400 Hz. Say you have connected a 4 Ohm power resistor, RATED 200 Watt! And AC average voltage ( not peak ) measures 20 Vac across this resistor. If you use 400 Hz testsignal, you can use most AC voltmeters. P(Watt) = (UxU) / R P = 20x20/4 -> gives 100 Watt If you measure same 20 V across 8 Ohm P = 20x20/8 -> gives 50 Watt
lineup |
#8 | |
Okay, it says here:
dB = 10 Log (1 / 1,000,000,000,000) = dB = 10 ( - 12) = -120 dB So, for power, -120 dB equals one trillionth the power. Multiply by 100 for percentage, and it is one ten billionth of one percent of the power.
#9 |
Right Keltic,
His question was about voltage though! |
#10 |
Hi Keltic,
you would need to be a wizard to come up with those numbers in this celtic land. 10log(p1/p2) for power ratios. 20log(v1/v2) for voltage ratios. No exceptions. Poo is spot on with the log base 10 bit as well.
regards Andrew T. |
| SVC to DVC conversion | madstamm | Subwoofers | 8 | 13th January 2008 04:45 PM |
| Cary v12 -> V12r Conversion Questions | Yukonsc | Tubes / Valves | 0 | 19th December 2006 02:17 PM |
| Best op amp for I/V conversion | legarem | Solid State | 13 | 28th August 2006 12:23 AM |
| Page generated in 0.16606 seconds (70.13% PHP - 29.87% MySQL) with 11 queries |
