Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st December 2005, 03:30 AM   #1
eelai is offline eelai  United States
Default wiring ground question
i need some simple advice. i'm building a projector with a built in dvd player. i'm basically hardwiring everything to a single three prong plug. my problem is: the dvd player is two pronged, so i've only got hot and neutral. everything else is grounded to the earth ground. so, is it neccessary to earth ground the dvd player, and if so, how do i go about doing that? any help is appreciated.
Old 22nd December 2005, 08:04 AM   #2
AndrewT is online now AndrewT  Scotland
US power is very definately different from UK power so you should get corroboration.
A two prong input plug indicates a double insulated mains product. This is confirmed by the double square label on the info panel.
A double insulated product does not need an earth connection AND an earth connection must not be added.
Conventional RCA output connectors are not connected back to mains earth and thus comply with this requirement.
regards Andrew T.
Old 22nd December 2005, 01:09 PM   #3
Stocker is offline Stocker  United States
What he said. Wire it up the right way with the two wires, and don't worry about the absent third.
That is, unless you are modifying the chassis... double insulation only goes so far. If (potentially live) metal parts will be exposed during normal operation, you might have to ask again...
Jesus loves you.
Ground isolation network / power switch wiring DcibeL Power Supplies 2 5th April 2006 12:43 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Ground question Bikeman Power Supplies 4 17th November 2004 10:23 AM
amp wiring, ground problem (wierd) Shift_vigoroso Car Audio 3 3rd December 2003 10:11 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Page generated in 0.08240 seconds (64.91% PHP - 35.09% MySQL) with 10 queries
