Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th December 2005, 07:01 PM   #1
Alves is offline Alves  Europe
Question Terminating a coaxial (isolated) interconnect
Greetings.
I have cut in half a pair of Wireworld interconnects, in order to make two shorter pairs, using WBT-0108 connectors.
The problem is that on these coaxial cables the micro conductors are isolated. Thus, no signal passes to the WBT connectors.
How can I remove the isolation from the micro conductors in each end, so that the current flows?
Thanks and regards,
Alves
Old 6th December 2005, 08:44 PM   #2
Alain Dupont's Avatar
Alves,
Use your soldering iron, to remove the insulation on the little wires...
I do it with a 50 watts iron, a piece of hard wood, good solder with resin core
and roll and press the cable under the iron ; it takes about 30 seconds to get it done...
Alain.
Old 7th December 2005, 02:29 AM   #3
PauSim is offline PauSim  Portugal
PauSim's Avatar
Hi Alves,
You could also use just the soldering iron (without solder) to melt the insulation, for that W108 copper-to-copper connection. Donīt forget to crimp the wires after.
Cheers
Paulo
Old 7th December 2005, 10:08 AM   #4
Alain and Paulo, thank you very much for the tips. I will give it a try.
Yes, the WBT-108 are the crimp version. I have tried the solder version RCA WBT-101 with WBT solder and the results were not so good as just screwing (crimping) the wire directly to the WBT-108. Possibly, my solder technique is not the best...
Alves
Re-terminating a XLR cable with RCA connectors fatwok Parts 9 14th February 2009 11:50 PM
Terminating Sennheiser HMD 280 Pro kinghong Parts 0 16th February 2007 07:41 PM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 06:34 AM
Page generated in 0.09350 seconds (51.02% PHP - 48.98% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
