| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I was just given an EPROM eraser which uses a 254nm lamp for the UV source... assuming the lamp is still good, is this wavelength suitable for PCB etching with the commonly available DIY chemistries?
Jesus loves you. |
#2 |
Nobody?
this wavelength seems (on Google) to be mostly used for killing microscopic thingies and erasing EPROMS... but will it work for DIY PCB etching?
Jesus loves you. |
#3 |
My workmate has tried the eraser lamps, but found plain old sunlight worked better. 254nm is too short, and too dangerous. Permanent damage threshold for your eyes is about 8 minutes! Short UV at that wavelength kills bacteria by crosslinking its DNA : ie causing massive genetic damage.
#4 |
Thanks for that. Maybe Ebay or a DIY water cleaner...
Jesus loves you. |
#5 |
Positiv 20 works at 340-420 nm.
#6 |
ah, ok thanks but the bulb is specified as 254, not 354nm.
Jesus loves you. |
#7 |
ok... but that was my point. I just didn't concluded that in the post because it was obvious :P
I use a Philips TL20W/05, but that's just when there isn't enough sunlight because the sun gives me much better results than artificial lighting. |
| Etching PCB:s | Loial | Parts | 105 | 12th April 2012 03:22 AM |
| How to do the etching | Karakacha | Parts | 9 | 28th November 2006 07:18 AM |
| Problem with etching PCB!!! Please help! | safetyman | Parts | 20 | 16th May 2006 05:35 PM |
| ENX bulb for PCB etching? | Stocker | Everything Else | 0 | 6th May 2006 02:22 AM |
| Etching PCB's - don't tell the wife pls! | jackinnj | Everything Else | 13 | 8th October 2002 12:35 PM |
| Page generated in 0.09829 seconds (63.92% PHP - 36.08% MySQL) with 10 queries |
