Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Were to find TEFLON Heatshrink???
Old 29th November 2005, 12:11 AM   #1
Guijs is offline Guijs  Brazil
Default Were to find TEFLON Heatshrink???
Were to find a non expensive Teflon Heatshrink? I need to cover a 12awg copper foil wire (from a Alpha core inductor) to build a speaker cable.
Thank you
Guilherme
Old 29th November 2005, 01:47 AM   #2
Stocker is offline Stocker  United States
expensive is in the eye of the beholder. How long are you thinking about and why does it have to be Teflon?
Jesus loves you.
Old 29th November 2005, 01:52 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Does Teflon shrink when heated ????
-Chris
Old 29th November 2005, 02:00 AM   #4
dr_digits is offline dr_digits  United States
There isn't any. It's all pricey. I haven't tried any in a long time, as it takes a LOT of heat to use. And I mean a lot, you can't use most heatguns, it'll take forever. You're better to use teflon tape from Mcmaster Carr, www.mcmastercarr.com
Old 29th November 2005, 02:36 AM   #5
PauSim is offline PauSim  Portugal
PauSim's Avatar
Check Farnell. They sell PTFE heatshrink. dr?digits is right. It takes ages to shrink, it doesn]t get a consistent shape and for sharp metal foil jacketing is even worse.
You would get practical results with polyolefin, but not perfect. Use teflon sealing tape between the foils and sticky polypropilene tape around them to keep the foils together and to protect against tarnishing. Cover the cable with techflex, terminate and that]s it.
Good luck.
Paulo
Old 29th November 2005, 02:40 AM   #6
That's what i'm thinking.... teflon would be very hard to shrink.
dr_digits,
Great site! Looks like that this PTFE Teflon Tape is what I need. Thanks
PaulSim,
I'll check with Farnell.
Old 29th November 2005, 04:00 AM   #7
Does a 0,001'' thick double-face tape used to "glue" the 0,1mm teflon sheet on the copper, will affect the dieletric properties???
Were to find TEFLON Heatshrink???Hide this!Advertise here!
How do you shrink heatshrink? Atilla Everything Else 26 23rd June 2009 01:46 PM
Interconnects - heatshrink v Teflon tube v tape, gauge v length otto88 Everything Else 42 25th May 2008 06:20 AM
Relation between strecher and heatshrink in ESL building GlidingDutchman Planars & Exotics 11 15th April 2008 07:25 PM
Techflex heatshrink movie_fan Parts 1 25th May 2005 08:38 AM
Looking for flexible Heatshrink Silver Stealth Everything Else 0 19th May 2002 12:06 PM
Copyright ©1999-2017 diyAudio
