Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th November 2005, 12:04 AM   #1
Default Rebuilding plastic parts?
There is a broken tooth on a plastic gear of my PlayStation's transport. Anyone knows what I can use to rebuild it?
I was thinking to make a mold with the other teeth, turn the gear and fill something inside. Now the problem is -what- do I put in there. I know that normally crazyglue and plastic powder works but there will be a mold in there and I don't have any plastic powder.
Antoine
http://dmsaudio.ca/
Old 20th November 2005, 04:26 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
Use superglue mixed with baking soda... my dad used it for years to fix old cheap watches where the strap pins tended to break the pin hole away... the soda stops the glue from melting the plastic.
Maybe fill the whole missing area and just use a small file to shape it... shouldn't be that hard to get a reasonable tooth.
Old 21st November 2005, 12:14 AM   #3
Wouldn't a little 30minute epoxy filled with chopped nylon or fiberglass
be the ticket? both are pretty readily available.
Plastic gears are often made of self lubricating, very difficult to bond to,
nylon or polyethylene - like the bottle that superglue comes in. You might have some luck seriously roughing up the exposed surfaces or drilling a lot of tiny holes into it.
Need help rebuilding old PA amplifier! bleubleu Tubes / Valves 5 17th May 2008 12:59 PM
Rebuilding my old boxies..... Rave Subwoofers 10 4th March 2005 06:43 AM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
rebuilding 6L6 amp ... suggestions? phonon Tubes / Valves 67 17th April 2003 12:27 AM
I'm rebuilding my amp Lisandro_P Everything Else 2 4th July 2002 08:53 AM
Page generated in 0.11572 seconds (55.07% PHP - 44.93% MySQL) with 10 queries
