| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have simulated an amp circuit to look at the power dissipation in all devices. My original input source is a low frequency (100Hz) sine wave generator, designed to put the amplifier a smidgeon below clipping.
Here's my question: What kind of source will cause maximum power dissipation in transistors (amplitudes being equal): sine, square, or triangle? |
#2 |
Depends on output amplitude. With max amplitude (clipping) square wave results lovest losses.
And for absolutely highest losses choice is square-wave, at output voltage half of your supply rails. For sine-wave highest losses result when output voltage is around 70% of rail voltage. |
#3 |
for even more fun you can use a 2 channel source (cheap soundcard)
tie the load between the 2 pwr amp outputs and by adjusting the relative phase of the 2 channel drive you can simulate any reactive impedance you want with a single resistive load by using different frequencies in the 2 channels you can exercise the amps over a wide range of the I-V output plane |
#4 | |
Hi Jcx,
I knew I was here for a reason. Quote:
Now can you elaborate on how to achieve the phase difference. Does that phase difference equal the reactive load that loads the output with a phase angle?
regards Andrew T. |
#5 |
linear technology SwCad III free spice simulator has a .wav output option - just use the independent sources to define any wave/relationship you want
of course you have to decide on phase angle to simulate L or C and magnitude depending on your load R and amp gain strictly speaking this gives equivalent output I-V relation to an arbitary complex load but since the load isn't really "reactive" you won't see possible instabilities that an actual reactive load could cause http://www.linear.com/company/software.jsp (rename attachment, deleting .txt extension to get LtSpice circuit file) plays fine thru winamp for me, i assume any soundcard driver can play 2 ch 16/48K |
#6 |
Thanks Jcx
regards Andrew T. |
| Running tubes at their maximum dissipation. | G | Tubes / Valves | 8 | 10th February 2008 06:11 PM |
| Maximum device dissipation | smithy666 | Solid State | 15 | 1st August 2007 08:45 AM |
| Heatsink for two STK4050V in maximum power | ElectroPower | Chip Amps | 2 | 24th July 2007 02:27 PM |
| What is power dissipation? | geminni | Everything Else | 7 | 14th January 2007 07:39 AM |
| Page generated in 0.14329 seconds (52.09% PHP - 47.91% MySQL) with 11 queries |
