pioneer sa9500II AMPS - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 19th November 2005, 02:19 PM   #11
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Here's another one from the back of an old amp.
Do you recognize the ground plug and AC outlets?
/Hugo
Old 19th November 2005, 05:52 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Nicole,
I think I understand the confusion now. Here in North America, these units were supplied with a two wire AC plug. That's why this is confusing to us over here.
The addition of the third ground connection may be law where you are. That is why one of our members from your area should speak to this.
Your fault sounds like the wire has broken just behind the AC plug boot, replacement of the plug would be the correct fix. It must be done in accordance with the laws in your area.
-Chris
Old 19th November 2005, 07:29 PM   #13
frugal-phile(tm)
planet10's Avatar
Default Re: pioneer sa9500II earthing????
Originally posted by djmaiden
but theres a round voltage selector which is currently set to 240 v
(not 220)....it has a screw in middle presumably so you can alter it if necessary...so i dont think this is a problem...as uk mains is usually
240v.
If the amp has one of these then it is not US Spec. At the time of this amp, it was against the rules to ship a unit that had any switchable mains capability to the extent that mass market items like this amp had a North American only power trafo with only a 115V primary.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th November 2005, 09:20 PM   #14
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
anatech seems to sum things up nicely.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 20th November 2005, 12:10 AM   #15
Default old amp fixing
hi,
yea i do recognize those ac outlet things....its practically the same on the back of my amp......."switched 150w....and unswitched 200w"(sorry but i dont even know what that is for really...; /)
......just wish i knew more about all this stuff but at least im starting to learn more now.....iv been djing for about 9 yrs but havnt really had much of a chance to learn all the real technical stuff yet,just used common sense up till now when it was needed....but id like to know alot more.
thanks for the pic....i appreciate all the help here as most people i know in my area who know about this stuff would not really help me much!!!!!;(
so cheers,thank god for computers eh...
nicole
Old 20th November 2005, 12:23 AM   #16
Default plugs on amp..
hi hugo...
yea its the standard uk one ...second from the left on your picture.
and it just has a 2 wired lead goin into it from the amp...no earth .
except when i got it someone had previously connected a wire from one of the ground terminals on bk of amp.. to the earth in the plug!!!!!!!!!!!.....pretty sure that this was unnecessary.....but not sure if this amp has the origional mains lead in it still...looks like it but cant be sure.
easy.,
snix..8)
Old 20th November 2005, 05:54 AM   #17
dce is offline dce  United States
Send a message via Yahoo to dce
Default sa9500II
Nicole,
Pls. try to take a picture of the back of your unit and the wirings
so it will be easy for everybody. Its kinda difficult to give you
information if we cannot see part of your unit.
I think everybody here is willing to help, but they are not much
familiar in electrical code there in your country.
cheers
dce
Old 20th November 2005, 11:01 AM   #18
Netlist's Avatar
Default Re: pioneer sa9500II AMPS
and makes a very unhealthy noise from the plug..
Nicole,
This simply indicates a broken wire or bad contact near or inside the mains plug as posted above.
You got it right in thinking that the plug you recognized is not likely the original.
In origin, the amp has only two wires and the plug has three pins.
In the past, someone connected a third wire (which was never there) from the plug to the chassis of the amplifier.
This chassis connection or ground therminal(s) are for turntable(s) as many of them need it connected to prevent hum.
Do yourself a favor and take your amp to someone who can fix this, i.e. a local electricity shop. If you're lucky they will fix it instantly and you will learn the most out of looking how they do it and asking a few questions.
The AC outlets on the back are there to provide current to other equipment connected to this amplifier, meaning that the other equipment needs to have a plug that fits in the outlets.
'Switched' will switch on the connected equipment when you switch on the main amp. 'Unswitched' means that the outlet always carries 240V when your amp is connected to the mains.
Don't stick anything in there.
/Hugo
Old 20th November 2005, 04:52 PM   #19
Default pioneer amp
hi hugo,
yes thats what i was thinking...well took that silly piece of wire out which was goin from the t/tables ground to the ac and i will cut the wire down later and see if this solves the dodgy connection.
thanks alot....you have been a help to me ,,,just so i can clarify things ,,,,and can probably fix this myself provided it is just a broken wire inside the mains lead....cheers....
will try it tonight.
easy,
nicole 8)
Old 21st November 2005, 06:21 AM   #20
diyAudio Editor
Variac's Avatar
Make sure to post if it works or we'll be worried.....
Pioneer SM83 PP amps jevta Tubes / Valves 3 26th September 2008 12:46 AM
80's Pioneer Amps highboy_coupe Car Audio 2 20th July 2007 01:54 AM
Summing (I/V) op-amps for Pioneer DV-59i hollowman Digital Source 2 12th March 2007 05:46 PM
Old Pioneer amps.quality as good as today? fazman Solid State 30 26th November 2006 06:07 PM
Copyright ©1999-2017 diyAudio
