Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th November 2005, 10:19 PM   #1
neutron7's Avatar
Default 2 transformers instead of "dual secondary" ?
parts express has these little torroids for sale for $5. they are 14v CT. i guerss they are they are approx 60 - 80va by comparing the weight to hammond ones.
anyways i was wondering if it would be safe to use 2 of them as a 28 + 28 by wiring them in parrallel on the primary side. what about the phase of the secondaries, does that have any effect? please see attached image
i was thinking of 2 per channel, and a fifth one for the preamp, thats $25
doh they are out of stock anyways
Old 6th November 2005, 11:28 PM   #2
bogicp is offline bogicp  Yugoslavia
bogicp's Avatar
Default Re: 2 transformers instead of "dual secondary" ?
Anyway, your wiring schematic is OK.
best regards
-boggy
Old 7th November 2005, 12:45 AM   #3
frugal-phile(tm)
planet10's Avatar
Should be no problem.... i've a whack of projects i'm going to do this in (ie 6 trafos for a VBIGC) but 28 V ? Do you mean you have 28V CT trafos? 14 VCT would also be called 7-0-7.(ie 14-0-14)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th November 2005, 04:08 AM   #4
Tweeker is offline Tweeker  United States
If you get phase wrong its 0V. They actually have dual secondaries rather than 7-0-7, or at least the 14-0-14 ones did. I just tied them together for 28VCT. You could use four to give dual 28V secondaries. The primaries would need to be series connected. The insulation would need to be up for this.
Old 7th November 2005, 04:52 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
Do you have 120 VAC mains? What voltage rating have the transformers? Check once more your connection of the primary side.
If your transformers are 120 V, the windings must be in parallel of cource.
/Per-Anders (my first name) or P-A as my friends call me
Old 7th November 2005, 04:53 AM   #6
frugal-phile(tm)
planet10's Avatar
Originally posted by Tweeker
2 14VCT/dual 7V secondary transformers giving a single 28V secondary.
Is this right? Err its wrong. Knew I was forgetting something.
I think you have the primaries wrong. If those are 7-0 + 0-7 trafos, you still only have 7-0-7. (55 VAC in 3.5-0-3.5 across each trafo)
If the primaris were wired in parallel you would have 14-0-14.
dave
Old 7th November 2005, 05:34 AM   #7
Er whoops, your right, primaries parallel. Other project on my mind confused me. (where two 120V xfmrs were run off 240V). Edit clock ran out on first post, then decided to actually make circuit to see what I was missing.
Old 7th November 2005, 04:33 PM   #8
I have some of the old PE 120V primary dual 14V (advertised as 28VCT) secondary unused for sale at my cost if anyone needs a few. 80VA each seems about right. Using a pair to supply a chipamp works just fine.
Interest Check: Plitron 300VA 18V Dual Secondary Standard Transformers twitchie Group Buys 108 21st October 2007 07:14 PM
GE "Dual Speaker" radio to Harmony H303 conversion : Help, please? Spasticteapot Tubes / Valves 16 12th July 2007 09:00 PM
dual secondary transformers jesserparker Chip Amps 14 13th January 2007 12:25 PM
WTB dual "modular" pots from Clarostat, Bourns ETC mihow Parts 0 15th September 2005 06:40 AM
Page generated in 0.12076 seconds (67.93% PHP - 32.07% MySQL) with 11 queries
