Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
J-B Weld for repairing lifted pad
Old 4th November 2005, 01:25 PM   #1
philibuster is offline philibuster  United States
Default J-B Weld for repairing lifted pad
hi all,
I have been attempting to repair a musical fidelity synthesis, and in the process of desoldering a multitude of components, I have found a few lifted pads. Some are only partially lifted, while others are completely lifted, held only by the trace. There are no breaks in the copper. It seems that the copper they used on these boards is VERY thin and desoldering causes rapid deterioration of the bond. Or, my desoldering skills are not up to snuff. I'm getting a variac in the mail on monday, so my 40W iron probably won't be too big of a problem any more.
At any rate, I was wondering if I could use J-B Weld to epoxy the pad back down. They say it's "non-conducting" and "withstands temperatures up to 500F" (from here: http://jbweld.net/products/jbweld.php). Anyway, is this a smart or a ill-concieved brain-child of mine? Thanks.
Also, any tips on desoldering without lifting pads and stuf would be great. I used a little sucker thing and some solder wick, but the solder wick just wicks the tinning right off my tip and it erodes. I'm also using lead-free solder of 96.5% Sn, 3% Ag, and .5% Cu, for my health and to say "I'm using lead free solder". I know i need higher temps for it, but I think my oversized iron is part of the problem. Thanks again.
Old 5th November 2005, 10:05 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I found just using the solder sucker was better than using a wick.
If it is a bit stubborn, a good idea is to add some solder onto the joint first using solder with lead (use it while it's still available), and then reheat and and whoosh with the sucker. This reduces the amount of heat that has to be applied.... less heat, less probs.
No longer DIY active
Old 5th November 2005, 10:09 AM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
When you remove components, it makes life a lot easier if you cut the leads off, and desolder them all seperately.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 5th November 2005, 11:48 AM   #4
I agree with you. except, I didn't have the foresight to do that. whoops.
Sometimes, if I don't get enough solder off, I have to heat the leads as I pull the component off. That's probably what killed it. That, and the beast of a soldering iron tip I use. The thing is a canoe paddle...
So, I used the J-B Weld on all my lifted pads tonight. It's curing under the heat of a 60W lamp. Hopefully, I can solder to the pads again, or I'll be doing some point to point soldering on pretty high voltage components- ~60V. I think I need a bigger sucker. Mine only has about 2.5" of travel. I should just use a vacuum cleaner with a drinking straw...
I'll tell you all how the J-B Weld works out. Thanks for the input.
J-B Weld for repairing lifted padHide this!Advertise here!
Help repairing a CS-400 glaforce Solid State 2 17th February 2008 08:55 PM
T - amp R2 pad lifted, any way around? CedMan Class D 7 12th November 2007 10:44 PM
How to restore burnt/lifted traces? valterdaw Car Audio 14 22nd November 2006 08:37 PM
repairing a/d/s/ 640 amp Ocelaris Car Audio 2 16th February 2006 02:35 AM
Possible to weld metal with small butane torches???? Hybrid fourdoor Equipment & Tools 13 27th September 2004 04:18 PM
