Capacitors, which type and brand sounds best to you?? Capacitors, which type and brand sounds best to you?? - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th November 2005, 04:44 AM   #1
John Biles is offline John Biles  Australia
John Biles's Avatar
Smile Capacitors, which type and brand sounds best to you??
Hello Everyone,
I tried a search and couldn't find what I was looking for, so if you know a link or thread please let me know.
What I want to know is what is the type and brand of Capacitor to use in the signal path. I already know you shouldn't use elctro caps in the signal path.
To you and all the experiments you have done over the years what capacitors stand out!!! and where can you buy them?
Old 4th November 2005, 07:49 AM   #2
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Mcap Supreme Siver Oil or the Silver Oil Golds.
Hear the real thing!
Old 5th November 2005, 09:40 AM   #3
John Biles's Avatar
Hello Soonqsc,
is the a website?
Old 5th November 2005, 10:28 AM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Hi John
Your question is too general - tubes or SS? While you probably can't go wrong with Mundorf Supreme it is very advisable to order a selection of caps and try them out yourself. In SS applications it's quite easy to design a circuit with 0v dc bias and compare a cap against a short piece of wire. Of course this won't account for possible high voltage bias effects.
I keep coming back to Jupiter - paper in bee's wax.
Old 5th November 2005, 12:51 PM   #5
soongsc's Avatar
Originally posted by analog_sa
Hi John
It's true there are other considerations. I just mentioned the Mcaps because I just tried them on speakers. I think it would be different if one were considering application in Power Supply or to Block DC.
Old 5th November 2005, 01:17 PM   #6
soongsc's Avatar
Originally posted by John Biles
Hello Soonqsc,
is the a website?
Here's an earlier site that does some comparisons.
http://home.versatel.nl/geenius/Cap.html
Old 9th November 2005, 03:23 AM   #7
Jay is offline Jay  Indonesia
Banned
Hi John, a common words from old audiophiles is that you can tailor the overall sound of your whole system by choosing suitable components. For example, if your overall system is too clinical, you may need a MKP. Every brand and type have "characters" of their own.
Super expensive caps may be better sounding, but may not improve too much if the circuit is not so good. Oil cap is usually wonderful, but you don't have to use them everywhere. You can buy smaller values like 100n/220n/470n, and parallel them with standard MKP/MKT with good result. These values are very usefull if you have audio hobby. They can be use as parallel cap in crossover, or as coupling cap in tube amps (they sometimes are too big in size for amplifiers, but if you can find low voltage rating, they will be very-very usefull)
Old 13th December 2005, 05:36 PM   #8
dreamer is offline dreamer  Hong Kong
Send a message via ICQ to dreamer
I tested many capacitor when I design a pre-amp last time, different brand got their own effect. However, based on the
material used to build the cap, the best is Telfon is the best.
For low cost but good result, WIMA FKP1 and FKP2 is very good too! For me, much better than MKP10.
Old 13th December 2005, 06:04 PM   #9
audiotux is offline audiotux  Germany
Hi John Biles ,
a good source for caps is www.thel.de and
www.schuro.de (forAudynCapPlus and little Vishays)
Greetings from Germany
Jürgen
Old 13th December 2005, 10:53 PM   #10
poobah is offline poobah  United States
poobah's Avatar
Save your money...
Use Sprague Orange Drops and call it good...
Capacitors, which type and brand sounds best to you??Hide this!Advertise here!
Nichicon Super Through Capacitors 15000uf 50V Brand New genther Swap Meet 0 30th September 2006 07:27 AM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Capacitors - Which type to use marlow Solid State 8 10th January 2002 05:13 PM
Copyright ©1999-2017 diyAudio
