| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Well, here it is, the lamest project of the end of the year 2005.
I found that a cheap soldering iron of mine simply got too hot to be really useful. I was always tinning it to keep from oxidation and the heat output was just too much. My solution to the problem? PWM, yes, Pulse Width Modulation. But the way I implemented it is what's so demented.. The idea came about easily and soon I began constructing the circuit from the top of my head. I started with an astable multivibrator using two transistors, then an RC integrator, then a single transistor comparator, then relay driver. Boy what a novel PWM device. It happens to operate at about 4Hz and with a pot varying the voltage to the emitter of the comparator, I can vary the duty cycle anywhere from 0% to 100%. The verdict? As ugly as this is, it performs beautifully. The temperature of the iron is now easy to control at the turn of a knob and there's no longer any high heat output mess happening. Just thought I'd add this archaicly styled circuit to the ideas of diy'ers...
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#2 |
Do you have any temperature sensing, or do you just try out what setting works?
#3 |
There is no sensing. I didn't need it to have feedback.
I just base it on duty cycle. 50% duty is half the power, therefore half the heat. It works well. I now can solder properly and not worry about the tip burning away.
#4 |
Did it Himself
50% duty is 1/4 the power
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
Yes, you are correct.
It's 4:00am, can you lay a blame on me?
#6 |
Mine's even more archaic - uses a simmerstat (cooker control) to do much the same thing
#7 | |
#8 |
You guys have me spinning now. I'm too tired to really think.
You are correct Christer in that it is 100% power half of the time. Then again, in typical PWM systems, I believe richie00boy is correct. EDIT: But let us not argue over the numbers too much. I just wanted to show my solution to the problem that faced me.
#9 |
Did it Himself
The thermal inertia of the iron will perform the integrating action akin to low-pass filtering so the net result will be the tip effectively sees 1/4 power
But yes electrically it's 100% power 50% time.
#10 |
Yes, the thermal inertia will work as a low-pass filter for the temperature. That means the temperature will be fairly stable and the same as if we had had 50 % power 100 % of the time. What temperature we actually get is a different issue, though. The relationship between power and temperature is all but linear.
| Page generated in 0.11473 seconds (72.58% PHP - 27.42% MySQL) with 9 queries |
