Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th October 2005, 08:16 AM   #1
Default PCB Design problem.. Pls advice
Here guys,
this isnt the first pcb i m designing.. but certainly quiet complicated.
actually the circuit generates frequency upto 50khz reqd for my purpose. though i know some of the kiddy basics about designing the pcb's, i would want to know about the tracks spacing and the ground plane width preferably.
Apart from this, i have general doubt since long.. In my PCB, does steep turn of tracks (90deg or slightly less) is desirable or a curvish routes (tangentials) more preferred.. specially when its dealing with medim of high frequency signals such as mine..!
Also, i use a Xtal generating 6MHz tone with 4060 IC. However, i need to use only 2 freq division o/ps from 4060.. Can i leave these remaining pins open .. or should i connect them to ground through a dummy high resistance load.
Pls advice..
Regards Prasanna
_____________
XI--TRONICS
Old 29th October 2005, 10:52 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
All CMOS input pins must be tied to ground or the supply voltage if not otherwise is said in the datasheet.
How are going to make the pcb, singlesided, doublesided, homebrewed or profesionally made?
Can you draw up a schematic and post it?
/Per-Anders (my first name) or P-A as my friends call me
Old 29th October 2005, 01:24 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Leave the unused output pins open.
Check the data sheet for supply voltage vs frequency performance.
Old 29th October 2005, 04:23 PM   #4
thnx a lot sir..,
I m making the board single sided.. its the ckt. of a stereo multiplxer. The biggest problem was, it used +12 GND and -12V.. I strictly need it operate on only 2 i/p supply pins .. that too max at 0-15V. Fortunately, that was possible and the problem is solved..
Still, i have one main pining by brain.. how do i place the traces.. With simple turns as they are reqd, or with forcibly curved tangetials..?? Pls advice..
Regds Prasanna.
_______________
XI Tronics
Old 29th October 2005, 04:51 PM   #5
peranders's Avatar
Keep it compact, avoid long traces and loops.
Strive to get good ground and supply voltage.
Old 29th October 2005, 05:19 PM   #6
sagarverma's Avatar
www.alternatezone.com
hi
hope the above link helps.it has a file going by the name of pcb design tutorial.
download the file.it has vital tips to help design a pcb.maybe the info in it might fulfil your purpose too
Class D Design needs your Advice alijoorabchi Class D 6 29th April 2007 10:09 PM
Another grounding problem-need advice. darkfenriz Solid State 27 11th July 2006 09:09 PM
Sub design - need a little advice Glen1 Subwoofers 4 16th February 2006 05:59 AM
Problem in an Encoder circuit design. Pls advice.. xitronics Parts 4 19th July 2005 03:14 PM
Page generated in 0.10462 seconds (70.12% PHP - 29.88% MySQL) with 10 queries
