the power of myth
It is hardly socialogical in this case, but a misunderstanding of basic electricity theory. Impedance matching is true and useful and tought in introductory courses, but it is not applicable in this case. The theorem says that if we have a source with a fixed impedance, we should select a load of equal impedance in order to maximize the power transmitted to the load. However, one cannot turn it backwards as they have done in this case. Here the load has a fixed impedance, not the source, so the theorem is not applicable.
A good rule: Don't believe everything you read :idea: There is no subsititute for true knowledge and understanding but it's sometimes hard filter out totally wrong "facts" if the source seems to be trustworthy and your own knowledge is little.
My question to the author is: Can you show your theories in the real word? I'll bet he can't.
Actually, this is hardly the first time this misunderstanding appears in audio. The problem is probably that this is a very basic and valid concept that is tought in all introductory courses, but some people are not so good at realizing what a theorem says and when it is applicable. This is misuse of a perfectly valid theorem.
Edit:
I think the theroem even did have a place in audio once. I am not good at valves, but AFAIK a valve amp typically has a rather high output impedance (without op transformer). For equipment with built in speaker, where amp and speaker were designed and selected together, there was probably a point in selecting a speaker with a matching impedance. I am guessing a bit here about valve equipment, but I suppose it was common to do so in order to both avoid an output transformer and to maximize the power into the speaker. The theorem looses its purpose for audio when we buy speakers separately since they have standardized impedance (usually 4 or 8 Ohms). The low output impedance of SS amps further makes the theorem totally uninteresting.
Stupid indeed..
What he's really trying to say is that if the amplifier had a source impedance of 8 ohms then you would get maximum power (into the speaker) if you chose an 8 ohm speaker.
Taking this principle further, we should be hunting for 0.00.. ohm speakers so we can "maximize" our power output.:D
This is a major weakness of the Internet. Anyone can publish without any scrutiny, whether from peer's or publisher. Have you ever tried to find reliable medical data? It's fightening! At least this is "just audio"......
Edit: added (into the speaker)
Christer said:
It would be really frightening if somebody made a marketing thing of this and started to sell 8 Ohm amplifiers, arguing that is optimal for 8 Ohm speakers. I'm sure many customers would think it sounded logical.
Well it would be logical if you are in the "no damping" camp, and don't mind throwing away half your power...... Enter Thorsten?.......
I'll be first in the queue to start selling 8 ohm balanced matched interconnects...
Um... I see nothing wrong on hyperphysics. In fact they are a valuable resource and should be referenced more often.
What you are misunderstanding is a basic concept of maximum power transfer vs. output impedance. Power transfer is maximized when the load impedance is equal to the Thevenin source impedance of the signal source. Let me put it this way:
Connect an ideal voltage source V in series with a resistor Ri. Now connect a load resistor RL to complete the loop. The current can be expressed as voltage V through the sum resistance, I = V / (Ri+RL). The voltage developed across RL is proportional to that current: VL = RL * [V / (Ri + RL)] = V*RL / (Ri+RL). Power is voltage times amperage, or PL = VL * I = [V / (Ri+RL)]*[V*RL / Ri+RL)], or
P = V^2*RL / (Ri+RL)^2 .
This says power goes up with the square of voltage, but the rest of the equation isn't easy to figure out by inspection. You could graph the equation with RL as the variable and see how it works, but there's a better way to find what we want. I'll take the derivative ("rate of change") of P with respect to RL. When dP/dRL = 0, we know we are at either a peak or valley in the above equation, because for a small change in RL, there's basically no change in P. Nice, eh?
This is a quotient rule problem so I won't write the steps; suffice it to say,
dP/dRL = V^2 * [(Ri-RL) / (Ri+RL)^3]
(yes, the denominator is cubed.)
That has even less meaning, but if we take dP/dRL = 0 and solve for RL, we can find all the peaks and valleys in the original equation. Now this part gets real fun -- I mean it, the answer just plops out in all its elegance:
First take distributive, seperate the +Ri and -RL terms (they still have a common denominator):
0 = V^2*Ri / (Ri+RL)^3 - V^2*RL / (Ri+RL)^3
Add thee negative term to both sides (move it to the left):
V^2*RL / (Ri+RL)^3 = V^2*Ri / (Ri+RL)^3
Now cancel some things. What can we cancel? Heck, almost the entire equation! V^2 drops, and the denominator too. We are left with:
RL = Ri.
This was found by taking the derivative, which means we used the same RL, Ri, etc. as in the original equation. Nothing's changed, so we can go back to it:
Since RL = Ri for dP/dRL = 0, we know when RL = Ri is either a maxima or minima. We don't know which! There are two ways to tell: 1. take the second derivative and determine if it is positive or negative; 2. look at values of P at, less than, and greater than, RL = Ri. (Remember RL is the variable and P is a function of RL, i.e., P(RL).)
I don't feel like taking the derivative again so let's try plugging values into P. Not real numbers, we don't need a specific case.. let's just set RL to some logical values. First of all, we need to know P at RL = Ri. This comes to P = V^2 / 4Ri. First of all, power and resistance cannot be negative because such would be meaningless. Second, even if voltage were negative, V^2 is always positive. This tells us P(Ri) (i.e., RL = Ri) is positive, so to prove it is a minima, we need to find values greater than V^2 / 4R.
A logical starting point is taking extremes: RL = 0 and infinity (i.e., short and open circuit). We know from electronics that both of these situations have zero power dissipated, but let's check just to make sure.
P(0) = V^2*(0) / (Ri + 0)^2
Anything times zero is zero, and zero divided by anything is zero. Zero is clearly less than V^2 / 4Ri, so this end checks out.
For large values of RL, we are tempted to take a specific case and say RL is some large value, say 1Gohm, but how do we know Ri isn't a teraohm? There are two ways to handle this: we can let RL equal to some arbitrary multiple of Ri, say two times, or let RL approach some insane value, like infinity. Both work: the first, taking RL = 2Ri, results in a coefficient of 2/9ths, which is less than the 1/4th coefficient we got for RL = Ri. If we take the limit as RL approaches infinity (you can't actually let RL = infinity because infinity isn't a number :) ), P goes to zero. (Think of it this way: as RL becomes much bigger than Ri, the denominator looks like RL squared. This cancels with the RL in the numerator giving V^2/RL [for large RL]. For even larger RL, P becomes a very small fraction, and eventually, zero. Since zero at both ends is less than 1/4 V^2/R, we can conclude that power is at a maximum at RL = Ri.
There. I did all the math, algebra, and even some calculus for 'ya to prove that Pmax is at RL = Ri.
What's that you say, so why do power amps have Zo != RL?
Yep, I just spent half an hour talking about ONLY Thevenin equivalent circuits. A power amplifier does not necessarily have an equivalent representative circuit inside it. In fact they rarely do (which does at least make Hyperphysics' diagram erroneous).
So what then? You have to understand the difference between maximum power and output impedance. So what is output impedance? It's the exact electrical equivalent of me putting on a policeman's clothes. Just because I look the part doesn't mean I have any legal power over you... In the same way, you can adjust any *active* electrical circuit to appear as as miliohm output impedance, but that doesn't mean you'll be pulling kiloamperes from it when you short the output!
Amplifiers also have to worry about efficiency. Take this example: say you generate a square wave with a pair of MOSFETs. MOSFETs are essentially electrical switches with a well-defined ON resistance. Say the squarewave is 10V tall and the FETs are one ohm each. If you designed the circuit for 90% efficiency, then you intended that the load be about 9 ohms -- 10V aross 9+1 ohms is 1 ampere, which is 9V across the output and 1V across whichever FET is turned on, and likewise, 9W output, 1W dissipated in the FET, hence 90% efficiency. This current situation has damping factor = 9, 9W power output and 90% efficiency. If you reduce load to 1 ohm, it matches the Thevenin resistance of the generator and the 10V supply is shared evenly across both: 5V in the FETs, 5V on the load. This makes 5 amps, which is 25W -- far more power than before -- but also puts 25W into the FETs, astronomically more than the *1W* they were chosen at design time!
In a linear amplifier, you can account for output impedance effects by detecting the loss and applying more signal in proportion. This is negative feedback. You still have the same old amplifier, so Zo can go stone dead zero perfection, but you're still left with the same limits on voltage and current.
Understand now?
Tim (*saves post for adding to website*)
No Tim, it is wrong. As I said previously, this is only interesting when the source impedance is fixed and you can choose the load impedance freely in order to maximize the power transfer. In this case, the load impedance, ie. the speaker, is fixed and this guy claims you should choose an amplifier with the same impedance as the speaker. This would meant that you have to burn away half the power in the amplifier to no purpose. You could use the theory correctly, though, so if you have for instance an amplifier with 0.1 Ohm output impedance, you should choose a speaker with 0.1 Ohm output impedance in order to maximize the power transfer. However, that is only relevant in theory, I am afraid, since no audio amplifier would be able to deliver the currents required for such low load impedances.
That's a great example how math with wrong assumpions leads to wrong answers.
Math stayed pure here, elegant...
dP/dRl makes not much sense, because it is very hard to change Rl, do you imagine dynamic speakers of 1mOhm or 1 MOhm impedance? I don't.
You should count dP/dPi because electronic circuit can have different Zout, like mOhms, MOhms, negative...
If you are able to count derivatives... well? I if one can use a hammer everything looks like a thumb.
BTW I mailed to the author and didn't get any answer so far.
No, it's quite right-- check the math yourself.
You're welcome to do the opposite, i.e. solve the equations with Ri variable. You'll come to the same conclusion in fact. :)
An aside: don't forget that equivalent circuits aren't real circuits. Be glad I didn't write a 1000 amp source with 0.01 ohm parallel source impedance (Norton equiv.)! :D
In my later FET based example, I mention what would happen if you attempted to match to an (uncompensated) amplifier, and noted that such conditions most often bring the amplifier out of design ratings. THAT is why doing it in general is a bad idea.
Zuh? Please show me where my maths are wrong. Can you give a proof contradicting Thevenin's theorem?
dP/dRl makes not much sense, because it is very hard to change Rl, do you imagine dynamic speakers of 1mOhm or 1 MOhm impedance? I don't.[/b]
Er, this applies to any source-load circuit. From spot welders to lightning bolts and everything inbetween, if you can establish a Thevenin equivalent circuit for the source, you can apply the power transfer theorem (which I proved above). It's quite easy to change RL, either by selecting resistors and graphing data points or by using a continuously variable resistor.
Taking it to exactly zero and near infinity is just one of the mathematical tools that's more powerful than a single experiment can be.
It takes just as much effort to change the source as it does to change the load, you'll note. ;) Actually it takes very little of either, because you can demonstrate this perfectly with a reasonably ideal voltage source (i.e., Zo >> RL) and two rheostats.
Tim
Maybe I was unclear, I meant that, contrary to what you claim, the hypersonics page is wrong. I honestly didn't wade through your maths since it seemed just to be a proof of power compensation, which we already know is correct. Once again, the problem is not that there is something wrong with the power compensation theorem; the problem is that the hypersonics page suggest using it where it is not appropriate.
Aren't we actually saying the same thing, but in different ways? Since the speaker impedance is fixed, we do not want to find an amplifier with matching impedance. If we could choose the speaker freely, we wouldn't want to match it to the amp output impedance, since the amp doesn't have the current capability.
Add in that the the speaker impedance is nominal. What are the chances that amp (of any kind SS, tube . . . .) output impedance vs. freq would ever remotely treack with speaker impedance vs. freq? Reractance is a pain, eh.
