| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Does anyone have a way to get a WAV form to listen to from the results of a Circuitmaker 'Export to Text' ASCII file?
--> Jim <-- ==>NorthSideRap.com<== |
#2 |
can probably be done in SciLab - a free MatLab workalike
recent versions of MathCad work with 16 bit wav files |
#3 |
Tow out of so many programs, which do text to wav conversion, aka read the text (try google...)
commercial: Aldo's Text-to-WAVE 3.0 http://www.aldostools.com/text-wav.exe freeware: AnalogX SayIt http://www.analogx.com/contents/down...udio/sayit.htm Is it that what you were looking for?
/alohka/ |
#4 |
Circuitmaker is a circuit simulation program.
You can export the waveform from the simulation that you run into an ascii file, basically which is a bunch of plot points and numbers representing the amplitude/frequency/etc of the waveform. I'd like to listen to it, that's all. I've Googled, and found two ASCII to WAV converters, neither of them make a ledgible sound when paired with my Circuitmaker ASCII output file.
#5 |
you could use LtSpice (SwitcherCad III) - free spice simulator with wav i/o
either simulate your circuit in LtSpice or it may be possible to "import" your ascii by reading as a PWL (Piece-Wise_Linear) source input file (undocumented feature, see Yahoo group LtSpice, tutorial file folder) in a sim and save it out in wav format |
| RS232 program to send ascii commands? | Stocker | Everything Else | 7 | 17th January 2006 05:00 PM |
| CircuitMaker | loovet | Pass Labs | 2 | 1st December 2003 08:53 PM |
| CircuitMaker 2000 | Asen | Everything Else | 7 | 1st March 2003 05:24 AM |
| Spice models for circuitmaker | ashok | Tubes / Valves | 5 | 8th February 2003 08:33 AM |
| Page generated in 0.24416 seconds (24.77% PHP - 75.23% MySQL) with 10 queries |
