Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Etching PCB's - don't tell the wife pls!
Old 8th October 2002, 02:55 AM   #11
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
peranders,
That sounds like the formula for the rocket fuel they use on the shuttle!! dangerous stuff they say.
Here are some amazing facts about the SSME from the Rocketdyne/Boeing site"
Rocketdyne's Space Shuttle Main Engine operates at greater temperature extremes than any mechanical system in common use today. The liquid hydrogen fuel is -423 degrees Fahrenheit, the second coldest liquid on Earth. When the hydrogen is burned with liquid oxygen, the temperature in the engine's combustion chamber reaches +6000 degrees Fahrenheit - that's higher than the boiling point of Iron.
The maximum equivalent horsepower developed by the three SSMEs is just over 37 million horsepower.
The energy released by three of Rocketdyne's Space Shuttle Main engines is equivalent to the output of 23 Hoover Dams.
Although not much larger than an automobile engine, the SSME high-pressure fuel turbopump generates 100 horsepower for each pound of its weight, while an automobile engine generates about one-half horsepower for each pound of its weight.
Even though Rocketdyne's SSME weighs one-seventh as much as a locomotive engine, its high-pressure fuel pump alone delivers as much horsepower as 28 locomotives, while its high-pressure oxidizer pump delivers the equivalent horsepower for 11 more.
If water, instead of fuel, were pumped by the three Space Shuttle Main Engines, an average family-sized swimming pool could be drained in 25 seconds.
The SSME high-pressure fuel turbopump main shaft rotates at 37,000 rpm compared to about 3,000 rpm for an automobile operating at 60 mph.
The discharge pressure of an SSME high-pressure fuel turbopump could send a column of liquid hydrogen 36 miles in the air "
Now this would make one heck of a speedy echant machine!!!
Mark
Old 8th October 2002, 05:16 AM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by till
Last weekend i made PCB for Zen V4, using 30% HCl and as much H2O2 as it begins to make bubbles, took about 2 min. i made it outdoors because of the gas coming out of the solution. No problems, very good PCB.
Of course you can skip the water but for a newbeginner, I think it's unsuitable. Be a little careful at first and then reduce the amount of water. Pure acid + H2O2 is like rocket fuel, very fast reaction, in fact you can etch a board within 15-30 seconds!
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 8th October 2002, 06:47 AM   #13
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Whoa... You must be <i>very</i> careful working with concentrated acid...
for safety, you must slowly add the acid TO the dilutant (water, H2O2) never vice-versa! This is especially important with concentrated acids, as they can get very hot very quickly, even boil explosivley, spraying you with concentrated acid!!!
Be careful fellas... full coverage goggles or face shield is a good idea, as is a chemical respirator, good ventilation, and first-aid supplies on hand, especially and eye-wash method of some sort. Chemicals, especially acids, are no joke... I used to work in materials engineering, and we had one bad accident and several close calls, even with all the safety equipment and procedures of a properly equipped and staffed lab...
Of course we worked with some serious stuff... Nitric acid, Hydro-Flouric Acid and a bunch of other metal etchants, mostly for preparing samples for microscopy. Still, HCl isn't friendly stuff.
I just to make sure all the newbies who read this understand the nature of this stuff!
I don't etch my own boards any more, but I recall being very frustrated with the painfully slow FeCl method. I would've jumped to try a high-speed etching technique with simple ingredients like this.
Anyway, I'm sure it works really well. Maybe if I decide to do my own boards again, I'll try it out.
Safe etching fellas...
- Chad.
Old 8th October 2002, 12:35 PM   #14
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default Sign for your lab
I wouldn't think of keeping hydrofluoric acid in the house. a couple years ago a sanit-man in NYC burned to death from someone's negligence placing the stuff in the trash. Hydrofluoric acid is used to etch glass, among other things. All t hese are nasty (how many of you audio DIY'rs have pH meters like me?)<p>found the following on the wwwwwwww:
Etching PCB's - don't tell the wife pls!Hide this!Advertise here!
Etching PCB:s Loial Parts 105 12th April 2012 03:22 AM
How to do the etching Karakacha Parts 9 28th November 2006 07:18 AM
Problem with etching PCB!!! Please help! safetyman Parts 20 16th May 2006 05:35 PM
ENX bulb for PCB etching? Stocker Everything Else 0 6th May 2006 02:22 AM
254nm UV for etching? Stocker Everything Else 6 10th December 2005 02:11 AM
