| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Can anyone recommend a good SPICE program to me? I am currently using AIMSpice (full version), but this is text based, and I'm looking for a reasonably priced graphical simulator like PSPICE that doesn't have the price tag, and doesn't have any limits to the number of parts or nodes used in a circuit.
Thank you! |
#3 |
Check out LTSpice / SwitcherCAD from Linear Technology. It's free, it features a graphical editor, features Gmin stepping to find the DC operating point, is quite fast, and it has no 'student edition' limitations. I have used it to occasionally simulate analog cells on IC's with 15000 MOSFET's in them.
#4 | |
#5 |
TopSpice lookes really good, can you make your own device models in it?
#6 | |
LtSpice is used internally by Linear for IC design and has very powerful features and active support at the Yahoo group - the main programmer often responds directly, fixes are incorporated nearly weekly Documentation is terse, you will need a generic spice book (or somebody else's tutorials) to learn spice with but LtSpice is the best Free package I've used |
#7 | |
The main problems I have with LTSpice are it's graphical editor (so I just don't use it anymore and feed LTSpice a .cir) and it's incapability to handle these kind of constructions: Code:
Rpure 3 4 'Rsh/mf*(l-dl)/(w-dw)*tfacp*(1+pvcp1*(tanh(pvcp2*abs(v(3,4)/(l-dl))+pvcp3)-tanh(pvcp3)))' |
#8 |
I use both LTspice and circuitmaker2000 demo... I used to run it on a AMD 200MHz with 48MB ram on win95 .. worked fine.. now on a AMD2700+ 1GB WinXP it runs even better..
LTspice is very nice, good working program and since it's free, you cann't beat the value for money. It's graphical schematic editor doesn't feel that nice.. but it works just fine... Circuitmaker2000 is commercial, but a demo versions is availeble. It has a nice grafical schematic editor that feels good.. it also comes with a PCB router programm ... goodluck, Thijs |
#9 |
DaBit,
while I'm not sure exactly what you mean for the expression to do you can use behavioral sources with abs, tanh and 30-40 other functions of circuit V, Vdiffs, currents, and sim_time in LtSpice remember: a Resistor is just a (terminal) Voltage Dependent Current Source and you could use .param to name and collect costants in a easy to find and edit block: .param R=1 B1 N001 N002 I=V(n001,n002)/{R} |
#10 | |
You can make your own models in it. Penzar has a demoversion with a limited number of nodes and transistors. It's at least worth a try. |
| Spice simulators and their engines | rtarbell | Everything Else | 3 | 10th July 2007 01:03 PM |
| Spice simulators and accuracy results | rtarbell | Everything Else | 35 | 31st May 2007 11:37 PM |
| Simulators and convergence | rtarbell | Everything Else | 6 | 15th June 2006 08:04 PM |
| Good begineers SPICE books ? | Fanuc | Solid State | 2 | 9th March 2006 06:57 PM |
| Simulators and clipping | rtarbell | Everything Else | 3 | 16th November 2005 11:33 PM |
| Page generated in 0.15174 seconds (67.01% PHP - 32.99% MySQL) with 10 queries |
