Re: Re: Just a test...
Argo. Scematics should be saved as gifs, then attached. Notice how the jpeg you posted has a "haze" around the edge of the text and the lines. These are artifacts from the jpg compression process.
A gif (if set to the minimum number of colors required for the image) will also be much smaller.
dave
argo said:Another test
dave
