Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 7th September 2005, 01:57 PM   #1
paulspencer's Avatar
Question HELP with kit: speaker protection and muting
I'm working on a kit I can't get to work!
http://www.altronics.com.au/index.as...=item&id=K5052
I've been meticulous with making sure I have the correct parts in the correct positions, measuring each before inserting ...
It is meant to use a relay to mute an amplifier outputs on turning on, and disconnect on turning off. However, it won't trip the relay! I have managed to trip the relay using a 12V plugpack, so the relay is ok.
Power supply - I have a 12.6V tranny centre tapped. At first I had it with the centre tap, but that only gave me 6V to trip the relay, not enough. So I went with another power supply option, insulating the centre tap and only using AC1 and AC1 from the tranny secondary. This meant putting in 2 extra diodes. Now I check the voltage at the relay contacts, now it is less than 2v!
Previously the muting light went on for 5 secs, then off but there was no click of the relay to go with it. Now after changing the power supply, the muting light stays on! Nothing happens!
What can I say ... I'm lost on this one! I'm semi confident that this thing would probably work fine if there was sufficient voltage at the relay contacts. It's a 12V relay. I'm puzzled that the change would reduce the voltage. Any suggestions from here? ...
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Speaker protection help ronjodu Chip Amps 9 16th July 2007 11:49 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
DIY system setup - muting, de-thumping, spkr protection, remotes etc ... paulspencer Everything Else 5 6th January 2005 12:29 PM
loudspeaker protection and muting circuit trouble :( Mattyo5 Solid State 1 21st March 2004 02:18 AM
Page generated in 0.09393 seconds (56.55% PHP - 43.45% MySQL) with 10 queries
