| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have modded the hell out of a boss effects pedal and to my dismay the 9 volt battery gets warm after about 15-20 minutes of operation. I also added a DPDT slider switch(installed via Craig Anderton style-with ground) to act as the power switch and found that the battery gets warm/ semi hot after about an hour in the "off" position. I added the power switch so I wouldn't have to open and close the enclosure repeatedly. Are there any modders/benders out there who have had this experience and successfully ended this issue? |
#2 |
This clearly indicates a high current draw or more likely a short.
Check your connections, the switch particularly. /Hugo |
| Purpose of 9-Volt Battery in Pearl? | rgheck | Pass Labs | 1 | 13th January 2007 06:04 PM |
| sla 12 volt battery for Chralize question | scott_m | Class D | 8 | 15th December 2005 09:18 AM |
| 12 volt battery voltage step up | ThSpeakerDude88 | Power Supplies | 3 | 2nd October 2005 03:08 AM |
| 48 volt battery charger | DPW666 | Solid State | 20 | 11th August 2003 04:01 AM |
| Page generated in 0.15770 seconds (32.15% PHP - 67.85% MySQL) with 10 queries |
