Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 26th June 2005, 01:04 PM   #1
freezz is offline freezz  Australia
Default Reducing Audio Line Output?
Hi All,
I have a Stereo preamp mixer which has a Line Output and is feeding into a Power Amp.
Can I somehow reduce the Audio Line output amplitude on the mixer using some sort of a attenuator, or perhaps inline resistors?
I'm finding that I have to have the amp volume controls very very low and still finding that my mixer output volume is set to half.
What I would like is to use my mixer volume controls to the fullest and not have the sound so load, but to do this I have to turn the amp to about one notch. What could be wrong?
PLEASE HELP!
Any suggestions would be appreciated
Freezz
rflachs@netspace.net.au
Old 26th June 2005, 01:12 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Reducing Audio Line Output?
Originally posted by freezz
Hi All,
PLEASE HELP!
Freezz
This is a bit unusual. Could it be that the preamp/mixer has both an unattenuated line output as well as a volume controlled line output or preamp output, that you are not using? Do you have a pic of the backside/plug field?
Edit: I think I misread your post. Forget my reply.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 26th June 2005, 05:17 PM   #3
moamps is offline moamps  Croatia
If you connected the mixer to a professional PA amplifier, the levels would be OK. But, if you connect the mixer to a home amplifier then the overall sistem gain will be too high. The simplest method to reduce the gain is inserting an L-pad resistive network (for example 10k/1K inside a cinch connector).
Milan
Old 27th June 2005, 05:31 AM   #4
Default Re: Re: Reducing Audio Line Output?
Hi Milan and thankyou for answering my thread.
Just letting you know it is connected to a Pro Amp, all used for entertainment (DJ Gear) and not a home amp.
I did look up the L-Pad as you've recommended, can I just put one resistor in series to each channel on the outputs? Will that effect the quality or anything else? The reason I'm asking because I would like to keep it plain and simple without inserting a sub PCB
Due to it being low signal I guess I would'nt need to use anything bigger than a quarter watt resistor? is this correct?
Once again many thanks
Freezz
Milan
Old 27th June 2005, 07:05 PM   #5
Default Re: Re: Re: Reducing Audio Line Output?
you need two resistors.
Look at the picture below (20dB pads).
All resistors are 1/4W.
Milan
Old 28th June 2005, 02:59 AM   #6
Enzo is offline Enzo  United States
The power amp has no level controls of its own?
Old 28th June 2005, 05:35 AM   #7
ctardi is offline ctardi  Canada
Send a message via MSN to ctardi Send a message via Yahoo to ctardi
If I were to want to do the same thing with a TRS Plug, would 2 resistors mid line work? I am having a bit of trouble understanding your diagram.
Old 28th June 2005, 05:50 AM   #8
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
If you want to use TRS, just wire it up as pin 2- tip, pin 3- ring, and pin 1- sleeve. It will work the same.
Old 28th June 2005, 06:47 AM   #9
Default Re: Re: Re: Re: Reducing Audio Line Output?
Hi Milan and thanks for the reply
This may sound stupid but why 2 resistors? Why not just have 1 resistor per output inline on the output connectors.
Many Thanks
Freezz
Milan
Old 28th June 2005, 07:21 AM   #10
Default Re: Re: Re: Re: Re: Reducing Audio Line Output?
Amplifiers usually have 47kohm input impedance. To get 20dB attenuation with this impedance, the series resistor shoud be around 470kohm. This is the high impedance Lpad which is prone to EMI's and may inject noise, linear amplitude and phase distortion into the system. (in a nutshell)
Milan
Reducing output transistors gruni Solid State 26 6th July 2009 03:22 PM
Multiple speakers on audio output line heckler0077 Parts 11 11th April 2007 10:57 PM
Reducing output of tweeter bawang Multi-Way 2 16th November 2006 01:27 AM
reducing output Lostcause Power Supplies 4 7th September 2006 09:50 PM
Reducing output voltage macce78 Chip Amps 16 17th January 2004 09:21 PM
Page generated in 0.14816 seconds (71.46% PHP - 28.54% MySQL) with 11 queries
