Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
DIY FM antenna, can it be better than radioshack junk?
Old 14th June 2005, 12:51 AM   #11
homer09 is offline homer09  Canada
homer09's Avatar
the back
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 14th June 2005, 12:52 AM   #12
homer09's Avatar
the dipole i use (obviously i stretch it out and orient it as best i can)
Old 15th June 2005, 01:53 AM   #13
TwoSpoons is offline TwoSpoons  New Zealand
TwoSpoons's Avatar
Ah, I thought as much. I too have one of those nasty ribbon antenna's. And my one is crap .
So there's hope for you yet!
This site shows you how to build a similar antenna, but tuned closer to your weak station. I'd try that first as its quick, cheap and easy.
Old 15th June 2005, 03:53 PM   #14
homer09's Avatar
Thanks, i will try this!
will connecting the crossbar of the antenna with 75-ohm coax be better than using more 300 ohm twin lead? i noticed the apparently very good FM Reflect dipole from C. Crane
http://www.ccrane.com/fm-reflect-antenna.aspx
uses 75 ohm to terminate. any other insight between the differences between this FM Reflect and a standard dipole?
Old 15th June 2005, 07:19 PM   #15
jimbo1968 is offline jimbo1968  United Kingdom
What's the difference? Is the 300ohm wire much better than that used in the ribbon antenna?
Old 15th June 2005, 07:23 PM   #16
dnsey is offline dnsey  United Kingdom
As Twospoons pointed out, a straight dipole is terminated at 75 Ohms, and a folded dipole at 300. (Actually it's a bit more complicated, especially if you start adding elements...).
What the DIY site describes is a folded dipole:
_____________________________________ |__________________ _________________|
so it needs a 300 Ohm cable.
The Drake looks like a straight dipole:
_______________________ ___________________
and will therefore require 75 Ohm cable.
EDIT: The site doesn't like my diagrams, but I hope you understand what I mean!
Old 15th June 2005, 07:26 PM   #17
homer09's Avatar
i have read that some wire used in cheap dipoles doesnt even have 300ohm impedence, some have closer to 200. thats one improvement.
second, my dipole is almost 6' long, which is terrible considering that is optimized for 78 MHz, when FM is 88-108 MHz and my problem station is 99.9 MHz. this will be the second improvement.
Still wondering about that FM reflect antenna and if anyone has any insight on how it is built inside?
Old 15th June 2005, 07:29 PM   #18
homer09's Avatar
Sorry what is the "Drake" is this the antenna i just posted a pic of? Because if it is, this one looks like a folded dipole to me, notice in the picture there are two runs of coax... how could it be using 75 ohm then?
Old 15th June 2005, 07:31 PM   #19
homer09's Avatar
another pic of the FM Reflect
Old 15th June 2005, 08:09 PM   #20
I have no idea where I got 'Drake' from!!
I was referring to the FM Reflect, which looked to me like a straight dipole, but I see from the larger pic that it's not.
As I said, it's not really as straightforward as all that (what is?) - the impedence actually varies with the point of attachment of the feeder. It's also quite possible that the two runs of the Reflect are not electrically conected - one may well be acting as a parasitic element.
The best feeder for a simple ribbon folded dipole, however, is 300 Ohm.
I'd be a bit dubious about the reports of some feeders being 200 Ohm - it's possibly so, but not an easy thing to measure, and will vary according to various extrinsic factors, so I wouldn't worry too much.
Just for fun, I've read that a pair of 'Slinky' spring toys arranged as a dipole can be very efficient - might be worth a try: cheap copies are available here in 'Pound Stores'.
DIY FM antenna, can it be better than radioshack junk?Hide this!Advertise here!
My DIY UcD amp from the junk box acid_k2 Class D 38 3rd September 2012 05:01 PM
What to do with RadioShack 40-1041? Spasticteapot Full Range 0 14th October 2006 08:14 PM
Radioshack special GC Dustin Haug Chip Amps 16 15th February 2004 03:22 PM
Dr.Bose and Radioshack.. Bose(o) Multi-Way 7 1st January 2003 06:43 PM
WTB: Radioshack RS 40-1354A psarin Swap Meet 1 5th April 2002 07:31 PM
Copyright ©1999-2017 diyAudio
