Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th November 2011, 05:36 PM   #71
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by tubelab.com View Post
In the US all FM radio stations used to transmit with a predominantly horizontal polarization.
Most stations I've built are circular polarization. Horizontal antennas were reserved for mountainous terrains with crippling multipath. Some sites I inherited were elliptical; instead of the 50% V, 50% H polarization of circular they employed less vertical power to balance the higher gain benefits of horizontal against the penetration benefits of circular.
Ears aren't microphones.
Old 4th November 2011, 05:46 PM   #72
hags is offline hags  United States
Originally Posted by DF96 View Post
AM MW ground wave is essentially vertical polarisation. We were talking about VHF FM. In the UK this started horizontal for best high quality long-distance propagation to fixed roof antennas, then added some vertical to help the majority who wanted portability and were not interested in quality.
That's correct, I was just giving two examples of vertical polarization.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 4th November 2011, 06:02 PM   #73
Colin is offline Colin  United Kingdom
This might be of interest. An experimental DIY FM antenna by John Linsley Hood, specifically designed to be mounted flat against the wall and be as unobtrusive as possible.
I built one years ago and it worked quite well but my location is line of site to an FM relay station, just over a mile away. It worked better than the usual rabbit ears wire.
Old 4th November 2011, 07:39 PM   #74
Nanook is offline Nanook  Canada
Nanook's Avatar
Default readu made options...
er...some ready made options: the original poster was looking for an indoor antenna setup. Being a Canuck myself, he should have just looked in his own backyard:
  • Magnum Dynalab has the SR-100 "Silver Ribbon" antenna, an easy to tune dipole type, with proper termination. The ST-2 is a verticle type, including a choke. This is similar to the Fanfare. Magnum based in Bramford,Ont.
  • UHF has a TV rabbit ear type, that has been apparently "hotrodded", based in Longueuil (Montreal), Quebec.
The J-pole looks interesting as a DIY type. Here's a thought: I get great reception on 99.3 (FM, but not in a metro area) with my Tivoli Model1 radio. It uses cell phone technology to receive and tune stations. Even without an antenna I can get a signal from over 100 miles away. With an antenna I am sure even better. Another option could be an old CB "whip" antenna.
Regarding many of the other "pre-made" and inexpensive options, I have an old Terk tabletop "square" FM antenna/tuneable amplifier, that simply doesn't work. At least not the way I think it should. I would stay away from many of these types, unless also suitable for HDTV, whether rabbit ear types or not. Perhaps I can attach this tuneable amplifier to an antenana and get som distant stations.
stew -"A sane man in an insane world appears insane."
Old 4th November 2011, 07:57 PM   #75
Really for indoor FM it's hard to beat a big ol' pair of rabbit ears. I've seen these at many local garage sales that seem to dwarf my 10' yagi. You can also check your local CL.
IMO the biggest bang for you indoor FM antenna buck.
Old 4th November 2011, 10:55 PM   #76
Nanook's Avatar
Default rabbit ears...
I agree, however the balun should be taken out . There' are significant drops across inexpensive baluns. Get a good balun or just cut the existing one out.
Apparently any "HDTV" rabbit ears are suitable as indoor high performing antennas. I gave a set away to a friend who could not get FM in his trade shop. Now he gets good reception. Often available for $10 or so new
An old CB antenna with a suitable choke (at least I think that's what the thing housed in the cylinderical housing on the ST-2 is). Make your own choke suitable to filter out TV, CB, etc Again, similar to the Fanfare FM-2, and Magnum Dynalan ST-2
Old 4th November 2011, 11:08 PM   #77
Absolutely, if you're serious about FM RF/AF performance replace the cheap baluns with coax baluns/chokes or toroids.
Old 6th November 2011, 04:59 PM   #78
Wow - a couple of pages of helpful responses to a post on a thread which was years old. Thank you very much everybody. I shall make my way through people's ideas and see where I end up.
Thank you again.
My DIY UcD amp from the junk box acid_k2 Class D 34 5th April 2012 08:03 AM
What to do with RadioShack 40-1041? Spasticteapot Full Range 0 14th October 2006 08:14 PM
Radioshack special GC Dustin Haug Chip Amps 16 15th February 2004 03:22 PM
Dr.Bose and Radioshack.. Bose(o) Multi-Way 7 1st January 2003 06:43 PM
WTB: Radioshack RS 40-1354A psarin Swap Meet 1 5th April 2002 07:31 PM
Page generated in 0.11755 seconds (77.56% PHP - 22.44% MySQL) with 11 queries
