Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 2nd November 2011, 03:29 PM   #61
hags is offline hags  United States
Originally Posted by multisync View Post
My understanding is that in North America FM radio is horizontal polarization. If one cannot install an outdoor antenna perhaps one on the ceiling that is painted the same colour as the ceiling will help hide it, or an atic if possible.
I'm not sure that all stations are.
"Some lures are designed to catch fish, others are designed to catch fisherman."
Old 2nd November 2011, 03:44 PM   #62
Ah, the OP cannot do roof or outside antennas.
Thought I'd post this anyway.
This is my latest build the 10', 88-92MHz high performance yagi design from High-Performance Yagis for 88–92 MHz
Old 4th November 2011, 02:51 AM   #63
kipman725's Avatar
Send a message via MSN to kipman725
Hi just an observation here. IF your using a dipole you need a balun to convert to a single ended signal. Otherwise relective mismatch hell.
CHR-70+Subs
Old 4th November 2011, 03:38 AM   #64
fubar3 is offline fubar3  Canada
Default FM radio antenna (indoor)
The antenna wizards hang out at Hugh Thompson's Digital Home .. It is a great resource for multimedia home entertainment. The Toronto/Buffalo region is like a "big bowl" so I can receive all the UHF tv stations using a small fractal antenna. But CTV moved down to channel 9 which I don't get on the fractal. For CTV, I have a loop about the size of a bicycle wheel hung on the wall. The loop is made from an extension cord with the sockets cut off and the 75ohm balun attached to the plug. Something like that will work for FM radio.
Old 4th November 2011, 07:33 AM   #65
es44 is offline es44  Denmark
es44's Avatar
I'm in love with the Moxon antenna. Never tried one for 75 ohm though, but according to this link: http://www.moxonantennaproject.com/f...%20Antenna.pdf it's doable.
No need to use plastic pipes, I use a wooden frame, and for indoor use, it's more than enough.
It doesn't take much time to make one, and the result is well worth it.
Good luck with Your Dx'ing
Old 4th November 2011, 12:55 PM   #66
DF96 is offline DF96  England
For broadcast reception you can often get away without a balun. The skeleton biconical linked from an earlier post can get some balun action by leading the coax cable away between the arms of the lower element. Not as good balun action as a full biconical, but that would be a bit large for indoors!
Old 4th November 2011, 02:16 PM   #67
tubelab.com's Avatar
My understanding is that in North America FM radio is horizontal polarization.....I'm not sure that all stations are.
In the US all FM radio stations used to transmit with a predominantly horizontal polarization. The transmitting antennas are multi bay arrays. The common practice was to tilt or rotate one or more bays to improve reception with vertically polarized car radio antennas. That is still the case for older station equipment.
Today most new broadcast installations employ hybrid antenna systems using a combination of vertical, horizontal and even circular polarity. This is done to offset the loss between horizontally polarized home receiving antennas and vertically polarized car radio antennas. Some information about FM transmitting antennas can be found here:
SWR Products
It is highly possible that the best polarity at the receiving end may not be perfectly horizontal. My experience in South Florida is that the strongest signal is usually received with a horizontal antenna, but it may be possible to reduce troublesome interference by tilting the antenna to reduce reception of the interferers signal. We have a lot of pirate broadcsters that radiate all sorts of random junk, but most seem top be vertical.
My experience has all been done with outdoor antennas and good measuring equipment. Indoor antennas will require much more experimenting since the signal strength can vary a lot with a small change of antenna position, especially in a concrete and steel building.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 4th November 2011, 02:30 PM   #68
True, especially for AM transmitters and car radios. Don't forget elliptical polarization.
Old 4th November 2011, 04:45 PM   #69
AM MW ground wave is essentially vertical polarisation. We were talking about VHF FM. In the UK this started horizontal for best high quality long-distance propagation to fixed roof antennas, then added some vertical to help the majority who wanted portability and were not interested in quality.
Old 4th November 2011, 04:52 PM   #70
kevinkr's Avatar
Here's a useful site for diy FM antenna builders: 88–108 MHz and FM tuner enthusiasts.
I built one of these: Wideband Vertical Omni - Works quite well, and can also be used in an attic, closet, etc ..
All of the materials required can be purchased at online metals here: http://www.onlinemetals.com/ and your local hardware store/home center.
Note that Beezley states in the latest edit on the above omni that only 6% of U.S. FM broadcasters still use horizontal polarization.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
My DIY UcD amp from the junk box acid_k2 Class D 38 3rd September 2012 05:01 PM
What to do with RadioShack 40-1041? Spasticteapot Full Range 0 14th October 2006 08:14 PM
Radioshack special GC Dustin Haug Chip Amps 16 15th February 2004 03:22 PM
Dr.Bose and Radioshack.. Bose(o) Multi-Way 7 1st January 2003 06:43 PM
WTB: Radioshack RS 40-1354A psarin Swap Meet 1 5th April 2002 07:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
