| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Does anybody know of sources for this commonly used diffuser/absorber?
I'm looking to make the DIY version of 8th Nerve's new Adapt Response Controllers for taming corner distortions. Essentially, these treatments are simply 2" rigid high density fiberglass in wedge-shaped wooden frames. The room facing side is supposed to be solid/reflective, while the fiberglass is mounted on the backside. Any thin fabric can be stretched over the frames and/or the fronts can be painted or veneered. As the pictures show, a small gap is supposed to exist between the panels and the associated walls to allow sound in. |
#2 |
Comercial building supply places will have what you want. Explain it as best as you can. Leave out the application. Georgia Pacific makes some so does Owens Corning or Dow Corning ( one bought out the other) Commercially it is used as exterior sheathing.
Mark
Mark |
#3 |
Speakerholic
Try a roofing supply store and ask to look at fiberglass base cap and torch-safe insulations.
Cal |
#4 |
I got some Owens Corning 703 in 2in thickness 2'x4' here in Augusta, GA at an insulation supply place. If I can get it here in small town USA you can surely get it in LA. Try a yahoo yellow pages search for insulation and start calling around to see if they will sell you small quantities. The Yahoo yellow pages category where I found the place here is:
Top > Business to Business > Construction and Real Estate > Thermal and Moisture Protection > Insulation > Supplies Some places only sell to contractors so you have to call around. Todd |
#5 | ||
Did you use it for acoustic treatments? If so, how did it work? And what have you learned from experience? Quote:
I think I'll toss together a few corner and seam brackets exactly like 8th Nerve's Response line. Just sew the cut insulation into some type of stretchable fabric and tack them into place. If that works at all, then I'll make mountable brackets out of 1/4" or 1/2" x 2" wood. It's interesting that they make the front room-facing side reflective and not absorbtive. So, it is the gap between the panel and the wall that allows soundwaves in, then the backside fiberglass traps and diffuses the normally reflected distortions. |
#6 |
Hmmm.....what have I done? Or what am I planning to eventually do? I read these forums, get great ideas, buy the stuff to do them and then never have time.
When I get my traps with 2" built I'll post some pictures and narrative. My plan is to create a small frame to form an 'L' on the back edge of the panel, actually two 2" panels together to form a 4" panel. This should give me enough solid material to keep the panel rigid and allow mounting of the outer fabric but still allow the panel to absorb plenty of sound as well. Don't hold you're breath waiting though. Todd |
#7 | |
1. a large wooden spool of 10awg flattened copper coil that I was going to wind my own DIY $$$ North Creek inductors - never happend (2 years and counting) 2. Mosfets, transformers, and 6 12" heatsinks for making Susan Parker's Zeus amp (5 months and counting) 3. A 2nd kit of Tube Lover's parallel TD1541A non-oversampling DAC w/ tube output stage (5 months) 4. a Brian GT Gainclone w/ transformers(3 months) 5. A quad of 211 transmitting tubes for a 1.kV+ 16W SET amp (3 months) I can say with almost certainty, none of those will ever see fruition. I will also check out Audio Circle's archives for treatment info. 8th Nerve also has their forum there. I'm probably going to make panel frames very similar to 8th Nerve's. It is the most common sense and simple approach. I'll also post pictures if I ver get around to building something. |
| Modes and Nodes and Density - Acoustic Math help | Pulse-R | Everything Else | 3 | 26th March 2009 07:32 AM |
| room treatments | chainenoble | Multi-Way | 5 | 17th March 2007 10:21 PM |
| UK Source, fiberglass acoustic panels, B.Brines | Wella | Full Range | 6 | 17th October 2005 08:53 PM |
| Room treatments - diffusion & absorption... | darkmoebius | Everything Else | 0 | 20th July 2005 02:35 AM |
| Page generated in 0.11641 seconds (71.73% PHP - 28.27% MySQL) with 10 queries |
