Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Sony home amp/receiver center channel cuts in/out.
Old 10th April 2005, 06:12 PM   #1
CptanPanic is offline CptanPanic  United States
Default Sony home amp/receiver center channel cuts in/out.
I have a sony amp that I have for about 5 years now, it has started
having a problem where the center channel in 5.1 mode will cut in/out, and when it does I hear a click, like a small relay. My questions are, 1) What are relays used for in an amplifier? 2) Any ideas on what to check for (Maybe a cold solder joint on a relay?) Receiver is Sony STR-SE501.
Thanks,
Brian
Old 12th April 2005, 05:05 AM   #2
gmphadte is offline gmphadte  India
U have broken solder problem.
Inspect the solders and solder the suspicious ones, especially at the heat generating components.
The suspecious solder points are the ones that have another inside circle on the solder pad and is formed by a crack.
Gajanan Phadte
Old 12th April 2005, 11:26 PM   #3
ace3000_1 is offline ace3000_1  Australia
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
Default Re: Sony home amp/receiver center channel cuts in/out.
Thanks,
Brian
Hmmmm Sony amp eh? I had one of these from new a while back (10 years ago), i took it back as it was full of cold solder joints. Took them 3months to fix the problem under warranty and when i got it back, same deal.
Like yours mine had the relay issue aswell. After speaking to the tech who did work on my receiver, he told me its a problem with the chassis being too weak and a grounding problem. Im not sure if this is the deal with yours, but it may give you some ideas.
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts."
Old 13th April 2005, 07:18 AM   #4
Thanks for the info, I will take it apart this weekend and see what I can find.
Old 23rd April 2005, 08:52 PM   #5
I resoldered all the main components, especially the relays, and it works perfect now, no cut outs.
Thanks,
CP
Old 23rd April 2005, 08:56 PM   #6
ace3000_1's Avatar
Nice one Cpt
Trev
Old 1st June 2005, 06:00 PM   #7
Elano is offline Elano  Brazil
Send a message via AIM to Elano Send a message via MSN to Elano Send a message via Yahoo to Elano
Default CptanPanic how to contact you?
Hello CptanPanic,
I have the same problem on mine, but I´m not as skilled as you, can you mail me the how to?
I have the STR-SE501-DE545-445 Service Manual, if you point me some directions there it wont be dificult.
Many thanks,
Elano
Old 2nd January 2010, 10:34 PM   #8
immeraufdemhund is offline immeraufdemhund
immeraufdemhund's Avatar
Send a message via ICQ to immeraufdemhund Send a message via AIM to immeraufdemhund
i bring back old thread. I have the same thing as you elano and i'm having the EXACT same problem with my sony str-de445. which one is the relays? all the blue boxes next to the line-out connections?
I hope that i can do the same as you, i am so tired of switching to 2ch. I just want digital sound like i paid for. Well hopefully soon i can build my own, but it's going to take some time.
Was kostet Europe, ich kaufe es!
Old 3rd January 2010, 12:36 AM   #9
I did it !!!! i did the same thing as the other fellow did and it's working great. I'm watching night at the museum and the sound used to be cut off already, but it's still going i'm so excited. Thank you so much for this website. I hope to keep learning and helping.
Old 6th February 2012, 01:17 AM   #10
vdotmatrix is offline vdotmatrix
Gee I don't know who'll read this but I am having the same issues i read all over the place about similar SONY receivers; mine is a a STR-DE545.
So the center speaker comes and goes as does the Woofer and left rear speaker.
Man....I out here all alone.
I am pretty handy, just wondering how can i recognize a COLD soldered joint and are there any more detailed solutions for this problem for these receivers?
thank in advance.
Sony home amp/receiver center channel cuts in/out.Hide this!Advertise here!
Nad T760 receiver- center channel weak hatrack71 Solid State 0 22nd June 2009 05:34 AM
One channel cuts out randomly dhowlan Analogue Source 0 25th September 2008 02:05 AM
Problem using Pro amp with home receiver Phatman91624 Subwoofers 5 10th August 2005 12:53 AM
Hey i need help with receiver........EXPERTS HELP(two channel receiver) Andre Baptiste Parts 1 1st May 2004 11:20 AM
Center Channel for Sony MB150Hs blackknight Multi-Way 9 6th February 2004 05:26 PM
Copyright ©1999-2017 diyAudio
