Switching off speakers when plugging in headphones? Switching off speakers when plugging in headphones? - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd August 2002, 05:32 PM   #1
Christian is offline Christian
Send a message via ICQ to Christian
Default Switching off speakers when plugging in headphones?
I would like my amp to turn off the speakers when I plug in my headphones. So I bought a headphone plug/contact with an internal switch. But, because I donít have a separate headphone amp ( just running them on the power amp, 330 Ohm resistor from speaker terminal) this switch now becomes useless. This, because the switch really is just a plate that contacts the signal pin.
I canít make the switch turn on relay, which in turn turns off the speakers, because I canít put a signal for the relay on the channel-pin.
Any bright ideas? The contact looks like this illustrated on a drawing and a pic.
Best Regards,
Chris V
Old 23rd August 2002, 05:35 PM   #2
Old 23rd August 2002, 11:27 PM   #3
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Cut off the old headphone plug and install a new one with the 330 resistors inside of it.
Old 26th August 2002, 01:45 AM   #4
Electro is offline Electro
Or
Put it after the pre-amp, but before the main amplifier.
Old 26th August 2002, 01:58 AM   #5
Electro:
I doubt that his pre-amp can drive the phones.
This whole deal is out of desperation anyway. Using a phone jack as a speaker on-off switch is not a particularly good idea in any arena except low-fi.
Old 26th August 2002, 02:04 AM   #6
ThingyNess is offline ThingyNess  Canada
Send a message via ICQ to ThingyNess
I'd just use the switch contacts inside the headphone jack to open an NC (normally closed) DPDT relay connected at the speaker output.
It'll cost a bit, but it should be relatively bulletproof.
Old 26th August 2002, 02:17 AM   #7
The switch contacts inside the jack have the audio signal. As Christian originally said, they are not available for anything else.
Old 26th August 2002, 02:28 AM   #8
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Switching off speakers when plugging in headphones? Send a message via AIM to Peter Daniel
Why don't you get a regular headphone jack, connect 330 ohm resistors to it from speakers output and install a switch at the back of your amp which can disconnect the speakers. It may be mechanical (like double pole AC switch) or toggle switch controlling a relay. Do you really need convenience of automatic speakers shutoff when you plug your phones?
www.audiosector.com
ďDo something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.Ē - JC
Old 26th August 2002, 06:36 AM   #9
Well, I'd really like to be that convenient, but it seems it doesn't work.
Maybe I'll have to go with the switch anyways, or find some other phone-jack.
/Chris,
Old 26th August 2002, 06:41 AM   #10
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
You can easily pass the necesarry voltage through the contacts in the jack to fire a relay to the speakers and use caps to bypass this voltage from getting into phones and the amp. I don't see why it wouldn't work, perhaps even very well... If you guys want a diagram of what I'm thinking, I'll happily supply it!
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Switching off speakers when plugging in headphones?Hide this!Advertise here!
Pregnancy headphones/ speakers? lgreen Multi-Way 3 30th December 2008 12:00 PM
Small tube amp for headphones/computer speakers?(first post) caveman24 Tubes / Valves 5 16th March 2008 10:42 PM
Plugging headphones into Echo Mia slowpogo Everything Else 2 28th February 2007 07:29 AM
DAC directly drives headphones & speakers ? Bernhard Digital Source 21 13th January 2005 05:02 PM
headphones that sound like speakers Xray Everything Else 6 14th October 2003 01:13 PM
Copyright ©1999-2017 diyAudio
