| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Minimalist
This past weekend I moved around my room and decided to use my TV s my monitor. I bought the Dayton VGA to componient video adapter from PE. I hooked it up to my TV and I get a signal, but it is moving from left to right over and over again. My computer works, I'm istting on the floor in my room with my old monitor next to me typing this. Does anyone know why this is not working, or what I can buy to make it work. My tv is a cheap advent 20".
Thanks, Josh |
#2 |
Minimalist
well, I got the s video connection to work, but I can bairly read the tv, I can see every pixel very easily.
#3 |
TV' screens have poor resulution...compared to monitor...
SivanandBalan |
#4 |
i would never use a TV as a monitor. Unless you have a HD TV, which is not your case, you are in for some big headaches using your computer with a TV monitor. The purpose of that connector is to watch movies, usually from DVD on your TV, definitely not for keeping up on www.diyaudio.com...
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#5 |
TVs make terrible monitors. Reading anything on them will just give you a headache. Great for playing games if you have a big TV, but no good for general use.
I would suggest acquiring a cheap monitor, and if you need a TV but don't want to CRTs cluttering up your room, get a PCI TV tuner and use the monitor for it.
http://mrevil.pwp.blueyonder.co.uk/ |
#6 |
Minimalist
I asked a few questions and found out why the VGA to componient video doesn't work. VGA and DVI are put out as progressive scan. My tv cannot interpret a progressive/HD input. I would have to have a down conversion video card. The guy said that the s video was a down conversion but was still in progressive and I was only recieving half of the pixels.
Last summer I did manage to put $3k into the bank from my summer job, and I've spent about $1.5k. I'm thinking about getting a HD tv. I was planning on waiting until 2007, when I would be a sophmore in college to buy a TV and they would be a lot less. I've done some research but its amazing how cheap you can get HDTV. I found a samsung 20" HDTV that was $160 plus $55 for shipping. This crappy advent was about $150 Any tips on what I should do on this TV situation? Thanks, Josh PS. I'm doing this so I can sit in my bed and get online via a wireless keyboard and mouse, tips on good vireless keyboard and mouse combos would be nice too. |
#7 |
Some warnings, even a HDTV will not give you the resolution of a computer screen. But if im not mistaken, HDTV gives you 1024 lines which is about the equivalent of 1024x768 on a comp monitor. So if thats enough for you, HDTV is a good idea.
I would still explore the idea of using an actual computer monitor. You could buy a tv-tuner, or even an old internal video card that supports tv-tunning, they have been around for a long time, and havent improved all that much, so im sure you could pick one up cheap. One that comes to mind is the matrox marvel g400-TV. this also has the added advantage of not needing a VCR, your harddrive can serve as a digital VCR, how cool is that? So basically, a comp equiped with a tv-card, DVD drive, soundcard/speakers and a 20 inch CRT/LCD could do everything you need. and if u still need a to use a vcr or gaming console, just plug it into your comp. your remote is now your wireless keyboard. i reccommend logitech, btw. IMHO are much superior to other keyboard/mice manufacturers (ie microsoft).
#8 |
Minimalist
I actually use 800x 600 resolution, and am planning on using it when I'm sitting in bed too.
Well I've talked to my Dad about this and I'm going to sell my TV and my monitor. Which should I get thought, a HDTV or a larger CRT monitor? I can find them sor about the same price, Even If I were getting a monitor that had a high resolution such as 1920 x 1440, would I really use all that "power" by using my 800 x 600 pixel computer setting? One reason I like the TV idea is no need for the tv-tuner, although, with a tv tuner couldn't I use my sound system for all the TV audio? Thanks, Josh |
#9 |
If you are sure you will only use 800x600 always, (i think thats way too little on a larger display like 21", but thats your choice) then i dont see much difference between a HDTV and a larger CRT. At that point i would look into the actual physical depth of both and see how much room space you have (since you say they are the same price).
The way i see it is the advantages of a HDTV is: standard remote, no need for computer (possibly 16:9 aspect ratio). Advantages of CRT + tvtuner: digital VCR, higher resolutions when sitting close or for gaming, no need for adaptor. Sound wise, both solutions are the same. AUX/line out to your gainclone the choice is yours.
#10 |
Minimalist
Well I just did a very very long post, and then it didn't go through, and I couldn't go back and copy my post.
Pretty much Brian told me about a deal where I can get a dell 20" widescreen monitor for $500. Cany anyone find a better deal. Space is no issue right now since my computer desk is about 32" deep. My resolution is low because on higher resolution such as 1280x 1024 the words are very small, and I will be about 6 feet away from the monitor. Would a 17" 16:9 have a bigger movie picture than a 4:3 20" when watching movies in widescreen? there seem to be good prices at mwave I wave been using www.shopping.com Any suggestions on good places to shop or deals that you all know of? Thanks, Josh |
| Computer Monitor Transformers | Lusso5 | Parts | 3 | 8th April 2004 01:33 PM |
| Shielded center and my computer monitor | owdi | Multi-Way | 0 | 16th September 2003 11:39 PM |
| Page generated in 0.12047 seconds (80.31% PHP - 19.69% MySQL) with 10 queries |
