Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th March 2005, 05:31 PM   #1
pburke is offline pburke  Germany
Default How to reduce attenuation of a 25k pot?
I have a couple nice 25K Noble pots and would like to use them for a headphone amp/DAC output (DDDAC1543 with 16 DAC chips). The problem is that the attenuation of those pots is far too aggressive for what I need. No matter how I wire them, it's almost an on/off situation. I think a 2k attenuator would be more appropriate for what I need.
Can I just add a resistor in parallel with the attenuator to reduce it's range, or would that mess up the pots logarhythmic curve?
Peter
Old 28th March 2005, 06:01 PM   #2
homer09 is offline homer09  Canada
homer09's Avatar
i dont see how a different value pot will attenuate less or more.
sounds to me like you wired your pot wrong. A properly wired pot functions as a voltage divider. What determines attenuation is ratio between the two parts of the resistor (separated by the wiper). So if you have a 2k pot or a 1Meg pot, the attenuation will be the same!
check that you have not wired your pot backwards as an anti-log pot. This would mean that instead of voltage input slowly increasing in a logarithmic fashion, it would go the other way, increase very fast than slowly producing an almost on/off behaviour when used as a volume control.
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 28th March 2005, 06:10 PM   #3
Bill Fitzpatrick's Avatar
It sounds to me like you have the phones attached to the pot wiper. If that's the case you are going to need a headphone amplifer circuit after the pot.
Old 28th March 2005, 06:32 PM   #4
actually, the pot was wired correctly and the wiper was going to ground. However, I had it before the coupling caps and not after, which messed with the DAC's vref... d'uh!
trying it behind the caps now.
Peter
attenuation using I/V ailouros6 Digital Source 14 15th October 2008 06:20 PM
XLR to RCA with attenuation pad. KOL69 Everything Else 1 24th April 2008 11:10 PM
hum attenuation AndrewT Power Supplies 3 2nd July 2006 09:12 PM
10 dB attenuation box june Parts 2 20th July 2004 04:07 AM
Attenuation Nappylady Multi-Way 3 18th February 2003 12:07 PM
Page generated in 0.09206 seconds (69.66% PHP - 30.34% MySQL) with 10 queries
