Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd March 2005, 09:20 AM   #1
Default What should be the sequence....
What should be the sequence of the following blocks in the audio chain:
1. 7-band Equalizer
2. Bass and Treble controls
3. Compressor/ Expander
4. Volume control.
Is there an article/ justification for the above?
Thanks and regards.
bimbla.
Old 23rd March 2005, 09:30 AM   #2
Frank Berry's Avatar
Default Re: What should be the sequence....
1. 7-band Equalizer
4. Volume control.
Thanks and regards.
bimbla.
Generally, the Compressor/Expander should come first and the Volume Control should come last.
If you put the Expander/Compressor after the EQ, it will "pump" if the bass or treble is boosted.
Frank
Old 23rd March 2005, 10:55 AM   #3
Default Audio block sequence....
Mr. Frank Berry wrote: Generally, the Compressor/Expander should come first and the Volume Control should come last.
The default flow for SigmaDSP AD1954 from Analog Devices has the equalizers first, tone/vol next and compressors last.
So this is a mistake right?
Thanks and regards,
bimbla.
NAD T763 disassembly sequence HD2000 Solid State 0 6th April 2008 04:03 AM
start-up sequence of Aikido preamp / SS power amp cbutterworth Tubes / Valves 5 7th May 2007 12:29 PM
Behringer XO sequence rick57 Multi-Way 6 11th October 2006 05:07 AM
sequence of the 4 power transistors on heatsink Wagener Solid State 5 24th May 2004 04:27 AM
Sequence in which grounds are connected Saurav Tubes / Valves 17 7th July 2003 02:17 AM
Page generated in 0.08248 seconds (69.14% PHP - 30.86% MySQL) with 10 queries
