Audio-Sector discussion splitoff - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th March 2005, 03:57 PM   #21
Electrons are yellow and more is better!
peranders's Avatar
OK, it's better if you have wood and the "problem" only is at the hot side but it's also a good thing to make the pcb so it's possible to use a metal case. Shielding is never wrong.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 18th March 2005, 03:58 PM   #22
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
As I mentioned, you can also use metal case if proper standoffs are used. Why do you choose not to comprehend it?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th March 2005, 04:00 PM   #23
And what problem you expect at the hot ?
www.audiosector.com
Old 18th March 2005, 04:02 PM   #24
UrSv is offline UrSv  Sweden
UrSv's Avatar
What do you mean by that Peter?
Clearly it must be obvious that Per-Anders has a point and is right in this questioning and that you are not. The problem clearly lies in that he FULLY understands what rules and design issues are being questioned and you do not i.e. he DOES comprehend but you do not.
Personally I would, as a consumer take it as a clear insult, that my safety is disregarded.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 18th March 2005, 04:03 PM   #25
Clearly it must be obvious that Per-Anders has a point and is right in this questioning and that you are not. The problem clearly lies in that he FULLY understands what rules and design issues are being questioned and you do not.
What exactly is his point? He mentioned creepage and 8mm distance. My board in metal case complies with that requirement. What else is there that I'm not aware of?
www.audiosector.com
Old 18th March 2005, 04:08 PM   #26
peranders's Avatar
My point is: In the design process, try to get the safety issues clear so you don't have to think about this afterwards. They should be in the first room, nothing to be laughed at. Try to get the latest information in the subject. Listen what others have to say (they don't have to be right always).
How should this pcb be used and by whom?
Mains voltage, demands of enclosures, skill level of users etc.
Old 18th March 2005, 04:09 PM   #27
UrSv's Avatar
Well, according to my understanding he is indeed talking about the creepage distance as well as fusing and from the pictures you have shown the board has, as it seems, several violations to those rules.
UrSv
Old 18th March 2005, 04:11 PM   #28
My point is: In the design process, try to get the safety issues clear so you don't have to think about this afterwards. They should be in the first room, nothing to be laughed at. Try to get the latest imformation in the subject. Listen what others say (they don't have to be right always).
Can you point out specifically, which part of design here do not comply with safety regulations? I want details, not first room info.
www.audiosector.com
Old 18th March 2005, 04:12 PM   #29
Again, be more specific. Exactly what violations?
www.audiosector.com
Old 18th March 2005, 04:13 PM   #30
peranders's Avatar
Let's not pick a fight but I'll doubt very much that it's OK to solder fuses the way you have done.
When we use soldered fuses at work we have special sockets for this so you won't melt the solder inside the fuse.
The main issue was that your pcb wasn't so good for a metal case.
Audio sector gainclone. dome406 Chip Amps 35 16th February 2013 02:32 AM
audio sector- lm4780 kit richyrich212t Chip Amps 1 25th August 2007 11:14 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 02:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 06:49 PM
Help with Audio Sector NOS DAC vdi_nenna Digital Source 14 14th January 2007 04:31 AM
Copyright ©1999-2017 diyAudio
