Go Back   Home > Forums > General Interest > Everything Else
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 10th March 2005, 12:37 AM   #31
RHosch is offline RHosch
Oh for heaven's sake, if this is a homework assignment don't go turning in the ramblings of KBK. You do want to stay in the course long enough to finish it, don't you?
The explanation is simple, and has been pointed out here twice. I would suggest redoing the experiment with a single wideband driver or single channel of headphones, and also doing trials at different sound pressure levels. A flat FR transducer is important if you want results reproducible by others, but not if the assignment is only a "neat... look at this" sort of experiment.
Fletcher Munson curves are generalized curves. Specific individuals will have somewhat different curves. Also, by definition the curves show how the human ear (generalized, again) varies in frequency response as a function of SPL. What you will find is that different listeners hear the transition at slightly different frequencies, and also that varying the SPL will result in a given listener hearing the transition at slightly different frequencies.
I suggest the single wideband driver because the presence of crossovers smearing a square wave might have some effect on the perceived transition frequency, and that would be interesting to note because the total energy in each harmonic would not be changed by the crossover. How the phase relationship between harmonic components of the signal affect the transition would be very interesting, and demonstrate an understanding of the phenomenon that your professor probably wouldn't expect. And while wideband drivers do have a limited frequency response, you have already established that the transition effect is high enough in frequency to be within the operating range of good widebands. If you really wanted to do a nice study (not sure how important the assignment is), insert a variable all-pass circuit in line that has an Fc near the transition frequency and try to isolate the role of harmonic phase relationships, or document the absence thereof.
Finally, follow up by examining published F-M curves (and the more recent ones... don't recall the name) and compare the perceived loudness of the fundamental and the second harmonic at the SPL corresponding to the proportion of the signal each contrubutes to a square wave at the SPL you used to test. See if those perceived loudness curves for the two frequency components happen to cross at the transition frequency you observed (in a given trial)....
Old 10th March 2005, 08:13 AM   #32
Carondimonio's Avatar
Originally posted by dnsey
It therefore seems likely that the first harmonic of the sq wave is more easily perceived than the fundemental frequency.
Originally posted by jeff mai
The above is the answer, but no one seems to have understood. There is no need to refer to diodes or transient perception to explain this.
The graph is only showing that the ear is increasingly less sensitive to frequencies below 200Hz. A square wave is a sine wave plus a series of harmonics (a perfect square wave would have an inifinite series.) Below 200Hz the ear perceives the first harmonic present in the square wave as being louder than the fundamental of the square wave. Therefore, where the fundamental of the sine wave of frequency "f" is below 200Hz, the required square wave frequency that is an audible match will be "f/2". Plain and simple.
Hi all,
it makes a lot of sense, besides one very small detail:
A perfect square wave has only ODD harmonics.
In other words, if you have a, say, 50Hz square wave, its sinus components are at 50, 150, 250 Hz and so on...
So, where does this "second harmonic", or "double freq. component" come from? Ear' s intermodulation distortion?
Bruno
Old 10th March 2005, 08:55 AM   #33
baggystevo82's Avatar
Send a message via MSN to baggystevo82
No, I was thinking the ability to hear the pressure waves of both flanks 'more seperately' at low frequencies. By the way it was mostly a 'neat look at this' question, I was just curious as to exactly why. I've got some more coursework to do now, but when I've got time I will try all these ideas out.
Steve
Old 11th March 2005, 05:18 AM   #34
jeff mai's Avatar
Of course this is correct. Don't I feel silly! Oops!
Now what?
Thread Tools
tuning forks for pure sine waves? cuibono Everything Else 13 17th September 2008 05:39 PM
sine waves on nos dac regal Digital Source 5 11th March 2007 10:38 PM
Making Square Waves? Tom Danley Multi-Way 29 22nd March 2006 02:46 PM
Basement Blaster doing square waves thoriated Multi-Way 2 6th August 2004 05:48 AM
Sine and square wave function generator Bricolo Parts 14 8th March 2003 12:45 AM
Page generated in 0.17154908 seconds (76.70% PHP - 23.30% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
