| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Have spent a lot of hours reading "diy anodizing pages" all say the same thing, use aluminium or lead cathode! Is it possible to use a stainless steel cathode instead?
#2 |
I don't know for sure, but you may find that a stainless cathode pollutes the bath with chromium, which is likely to affect the anodizing. There is a process called chromating which uses chromic acid to make an aluminum surface conductive, so you may get this instead of a nice aluminium oxide layer.
Lead sheet is easy to get (roofing lead). |
#3 |
I wouldn't recommend the substitution. Actually, after many failed attempts at DIY aluminum anodizing (following the various instructions found on literally dozens of websites), I gave it up completely. For that reason, I would be mighty afraid that any deviation would cause even more problems.
| Anodizing Question | N1ESE | Everything Else | 5 | 18th November 2008 12:58 AM |
| DIY Anodizing in Toronto | mantisory | Everything Else | 19 | 8th November 2007 10:34 PM |
| Anodizing tips please ... | 13DoW | Pass Labs | 5 | 30th November 2004 01:19 PM |
| DIY Anodizing | Andrew Steele | Everything Else | 11 | 30th May 2002 09:49 PM |
| Anodizing | doktor | Everything Else | 7 | 16th April 2001 08:05 PM |
| Page generated in 0.08766 seconds (72.78% PHP - 27.22% MySQL) with 10 queries |
