Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th February 2005, 02:01 PM   #1
Default Connecting a relay
I installed a relay in a bionaire humidifier to prevent the water sponges from drying.(The fan stops at the same time the empty light starts)
I'd ask a couple of questions:
1. How can I prevent the spark from happening when the motor is re-starting(When I fill it)
2. Is it OK if the relay coil feels hot thru the humidifier's plastic case?
Antoine
http://dmsaudio.ca/
Old 27th February 2005, 02:46 PM   #2
Did it Himself
richie00boy's Avatar
To reduce relay contact arcing, add a capacitor (100nF or so, high voltage) across the contacts.
The relay coil should not be hot! Have you chosen the correct coil voltage? There are different voltage ones as well as AC and DC ones.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 27th February 2005, 04:28 PM   #3
Where do I put this cap, between hot and motor?
It's powered on 120VAC and is a 125VAC coil. Well, maybe it's just warm.
Also, when the coil is active, there's interference in the TV picture.(And when the coil changes position, even when the contacts are unplugged, we see it in the picture and hear a pop)
EDIT:
I found it's supposed to be warm here:
http://www.naisweb.com/e/relaye/mech...i/idamo5w.html
It's an AC coil.
Antoine
http://dmsaudio.ca/
Old 27th February 2005, 05:02 PM   #4
Frank Berry's Avatar
Add the capacitor across the HOT contact and the contact the feeds the humidistat and motor. You might reduce the arcing even more if you add a little resistance in series with the capacitor.
Frank
Old 1st March 2005, 01:06 PM   #5
100nF, even with AC?
Antoine
http://dmsaudio.ca/
Old 1st March 2005, 01:50 PM   #6
Did it Himself
I use a 4700nF Y rated capacitor as if that fails it will fail open.
Old 2nd March 2005, 10:35 PM   #7
And what do I do for the coil interference?(In the TV)
Antoine
http://dmsaudio.ca/
Old 3rd March 2005, 06:44 PM   #8
Did it Himself
I can't see how energising a relay coil causes major EMI. Have you definitely checked there is not something else wrong? You could try connecting another of those Y rated caps across the coil to snub noise as a last resort. I think the problem lies elsewhere though.
Old 3rd March 2005, 09:38 PM   #9
Low band VHF signals are affected(2-6).
When I listen to one of these on my PC monitor , there are bright vertical noise stripes in the picture.
The coil is AC(Maybe there's a difference) and 1/3HP.
Antoine
http://dmsaudio.ca/
need help connecting pro amp to pc joka22 Solid State 23 6th July 2007 12:43 AM
connecting a pot jarthel Parts 8 3rd September 2006 09:54 PM
Need help with connecting OPT. juoto Tubes / Valves 1 17th January 2006 06:51 PM
Page generated in 0.10849 seconds (72.95% PHP - 27.05% MySQL) with 11 queries
