| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Reading a few opinions on the usefullness of simulation results in another thread, I wondered what everyone else thinks and if there are any tips for getting the most out of sims.
Personally I simulate a lot. It's very rare for me to build a circuit without having simulated it first, unless it's very simple. I usually find the measured performance of real circuits matches the simulations with uncanny accuracy. There are a few caveats though:
That's everything I can think of right now.
https://mrevil.asvachin.eu/ |
#2 |
I think you're quite complete. On the stability issue, I have found that sometimes adding a few pF to the inputs of opamps (and output) helps to get closer to the real thing: it will often oscillate as in the real world, unless you take measures.
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Actually, i have more problems with oscilation during simulation then in the real world. ( using multisim )
Rudy |
#4 |
i think simulation is very usefull for digital circuits
if you are not living on the edge you are taking too much space |
#5 |
When people get to talking about simulation, there's always some excuse as to why it doesn't match reality. Be it the code, the models, the user who doesn't know what he's doing...
Reminds me of religion. When something goes awry, you're supposed to pray. Prayer didn't work? Well, you didn't pray hard enough, or god had other things on her mind right then, or you'll get your wish in some other unexpected way, or... Grey |
#6 | |
\Jens |
#7 | |
Most of the time the difference between sims and reality is negligible. Even when there is a difference, this can in itself be informative: By adding stray impedances until the sims resemble real results (like the caps across op-amp inputs that janneman mentioned), it's often possible to determine why a circuit is not functioning as expected. Many times this has shown me that a particular track is too inductive, allowing me to fix it much more quickly than using measurements alone.
#8 |
Simulations are good, and useful, so long as you bear in mind that they are just simulations and inherently imperfect. Which statement I shall backup by pointing out that any transient sim is a discretized version of a continuous system. Hence you can get instability in the sim thats not there in the real thing, and vice versa.
I use sims a lot, to get me in the ballpark, then I build the thing on the bench. |
#9 |
Yes, but the question is...how many potentially useful designs get abandoned because the simulation claims it won't work? You don't know that it won't work (or, conversely, that it will) until you build it. Case in point--the Aleph-X. Had I been "designing" it in a simulator, I would have abandoned the concept entirely because the simulator would have told me that it wouldn't work. Only, it does work, in spite of a gaggle of people with simulators telling me it doesn't.
Save time? Hardly. I can pull a resistor and solder it in as fast or faster than you can simulate it and have 100% confidence in the result--after all, it's reality. You may think you have 100% confidence in your result, but... To me, this is all part of a disturbing trend wherein people insulate themselves from reality. They tell themselves that they're gaining a better understanding of things, but bit by bit they are actually disengaging from the real world. There's a lot of it going on in politics, religion, and the everyday things that we do. It's gotten to the point where at least some of the people, some of the time, are unable to judge reality accurately when they are forcibly confronted with it. They retreat to their sanitized, simplified versions in order to cope. I think I need to write a story about this... Grey |
#10 | |
| Reality Check | jdlech | Multi-Way | 11 | 26th January 2008 05:55 AM |
| Specs VS reality | ecl86 | Subwoofers | 2 | 20th September 2007 02:07 PM |
| Crossover Reality Check??? | jocko_nc | Multi-Way | 1 | 6th February 2007 09:21 AM |
| Acoustic Reality Ear 2 Amp | Harmon | Digital Source | 33 | 17th February 2005 09:16 PM |
| Reality check | analog_sa | Chip Amps | 2 | 10th November 2003 09:30 PM |
| Page generated in 0.13092 seconds (78.74% PHP - 21.26% MySQL) with 10 queries |
