| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Well, recently I popped down to a lower res on my monitor, and that allowed me to get a higher refresh rate ( i figured a higher one might help my headaches). so i went from 60hz to 85hz(within limits of monitor at that res.) this helped with the headaches, but i lost ALOT of brightness for some reason... and i also noticed that when i use the degauss function, i get my brightness back for about 5 secnds. I tried going back to 60hz but headaches came back
those 19" samsung sync masters are looking very appealing right now... and pinkmouse, i know you dont advise opening up CRTs, and thats not what im asking, im saying is there a problem inside of here that i could get fixed by a pro? so please dont lock my topic saying its dangerous to play inside a CRT...i already know this, and dont plan on doing it anytime soon. also another question, would an average quality 27" crt have high enough sharpness and detail to use a 1024x786 or 1240x1024 res(see all my descktop icons, still be able to do word proscessing etc)?
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!! EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!! |
#2 |
Isn't there an intermediate setting between 60 and 85hz? I think it's 72Hz. Try that, if you can.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
#3 |
Doesnt help, no brighter, no dimmer.
#4 |
Time for some percussive maintenance?
#5 |
come on SOMEONE must know whats wrong! its almost as if the monitor isnt getting enough power :S.
#6 |
Dude, your monitor is on the outs, or Dell ahem... "smiled" on the refresh rate specs a bit. If setting your refresh rate higher than 60Hz causes problems, deal with the headaches or get a new monitor.
Sorry, I wish I had a better answer. Maybe someone else will. Oh, and I almost forgot... Pinkmouse isn't kidding. Stay out of the monitor case. I have a buddy that works at ARC here in the Twin Cities, and he HATES going near CRT's. He's a VERY experienced tech. Sorry, no lecture meant, but dead is dead, you know.
#7 |
Get youself a nice new LCD screen. Some CRTs especially if they are a few years old look almost out of focus compared to a LCD which are very sharp. If your current screen is giving you headaches I'm sure a new one to solve the problem would be worth every cent.
#8 |
with daily use, a 4 year old monitor is shot anyhow. The guns get used up after a while. It may still be useable but nowhere near a new monitor, likely as not.
Jesus loves you. |
#9 |
xstephanx, I would strongly recommend you to get a cheap 19" Samsung monitor.
I got one, it's 1280x1024 at 85 Hz, good quality and no headaches. Any resolution under that, so 1024x178 and under, you can go higher than 100 Hz refresh rate...
DIYaudio for President ! |
#10 |
i wanta 19" sync master
. Im going to be watching dvds exclusively on my pc soon, so a cheap lcd with a low reponse time is not an option.(dont bother argue with me on this, i cant stand ghosting, and im just going to argue back)
| counterpoint sa100 headaches | pothound | Solid State | 46 | 26th October 2007 10:05 PM |
| forum headaches | multi-volti | Forum Problems | 7 | 9th September 2007 05:07 PM |
| impedance mismatch headaches. | xstephanx | Multi-Way | 11 | 10th April 2006 06:36 PM |
| Replacing Speaker Caps (literally) | Nai | Multi-Way | 0 | 5th September 2004 10:16 PM |
| Page generated in 0.10102 seconds (78.26% PHP - 21.74% MySQL) with 10 queries |
