Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th February 2005, 01:54 AM   #1
Send a message via Yahoo to antness
Default Pen to write on anodized aluminum / silkscreen
Is anyone aware of what kind of pen to use to write on anodized aluminum or silkscreening (such as on PCBs or panels). It needs to be a black pen with a fine tip. I've tried a standard Sharpie and it doesn't stick. Suggestions would be appreciated!
Looks like this should work
http://www.durablesupply.com/brmafipo.html
Old 6th February 2005, 04:48 AM   #2
purplepeople's Avatar
Try the Staedtler Mars Lumocolor Permanent 31 series. The ink was originally designed for plastics printed with the old flatbed blueprint plotters. This will stick to epoxy-based clear coats. It is as permanent as you can get without having it automatically ships with an MSDS.
:)ensen.
#313 Super fine tip (thin line)
#317 Medium tip (Sharpie width)
#318 Fine tip (between 313 and 317)
Those who claim to be making history are often the same ones repeating it.
Old 8th February 2005, 12:54 PM   #3
ericpeters's Avatar
What about using a standard laser or inkjet printer?
I'm looking for that old fashioned special paper with which one can make pictures to iron on t-shirts. Maybe you can Iron the same on anodized aluminium??
Old 8th February 2005, 01:07 PM   #4
jackinnj's Avatar
Bel Inc. sells "decal" paper for laser printers -- in 8.5x11 sheets -- you can make a very detailed panel using anything from your word-processing program to a CAD program -- and transfer to the anodized panel -- then apply a urethane finish to protect.
Anodized Aluminum Heat Sinks clm811 Group Buys 39 3rd February 2009 05:45 PM
Anodized Aluminum and Glue/Epoxy Bryan Tubes / Valves 22 18th May 2004 11:24 PM
Page generated in 0.07165 seconds (70.65% PHP - 29.35% MySQL) with 10 queries
