Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd February 2005, 08:03 AM   #1
Default ac voltage stabilizer
For a specific application I am looking for a voltage stabilizer circuit, to control a sinewage ( 50-60 Hz ) and keep the voltage
at 1 V peak.
Does anyone know about such device ?
Thanks.
Ari
Old 3rd February 2005, 08:12 AM   #2
Frank Berry's Avatar
You could use a 50 or 60 Hz wein bridge oscillator with a lightbulb in the feedback path to keep the level constant.
Frank
Old 3rd February 2005, 08:17 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
If you can tolerate some distortion you don't have to have light bulbs, just have the the gain at 3.1 or something, slightly over 3.
You can also use a sinus signal IC like XR2206 or ICL???? (Intersil had a very similar IC but I have forgotten the number)
http://www.exar.com/product.php?Prod...R2206&areaID=7
/Per-Anders (my first name) or P-A as my friends call me
Old 3rd February 2005, 12:38 PM   #4
Thank you Frank and thank you Per-Anders.
As soon as I build and test the device I'll let you know, just in case you would be interested.
It's a Turns-meter ( that is a device to measure the number of turns of a transformer winding).
I forgot to state that I might need quite a high current for the purpose ( say 2-3 amps at 1 Volt ).
Ari
Old 3rd February 2005, 03:50 PM   #5
jackinnj's Avatar
the LM317 can actually be used as an A.C. regulator -- it won't go down to 1.000V -- the lowest will be 1.25 which is the reference (or 1.249). The strategy is to use two devices. The picture below is from the product description at national.
i haven't done this personally, so YMMV.
oh, you can also modulate the ADJ pin of a three pin regulator with an a.c. source -- they make a terrible amplifier but it does work.
Old 3rd February 2005, 07:25 PM   #6
peranders's Avatar
Just use 12 VAC or something and two voltmeters, one at the primary side and one at the secondary. Take those two measurement values and divide. Why make it complicated?
Old 3rd February 2005, 08:55 PM   #7
Per-Anders,
I was considering the case where you do not know anything about the transformer ( not the primary turns, not the secondary turns, not the ratio ).
But, in fact, I can manage to have one turn added on top of the windings (which is possible in some cases), feed it with a known ac voltage and measure the voltage at each winding that I want to check.
This(these) voltages will disclose the number of turns based on the ratio.
Example : I feed the added turn with 0,2 Volts ( the current should not be too high, in most cases ). If I measure 200 Volts across one of the transformer's winding, then it should have 100 turns.
Of course, if more windings could be added, then the mesure would be more reliable and you could use a higher voltage than 0,2 V.
Correct ?
Ari
Old 8th February 2005, 04:22 AM   #8
Default ICL????
ICL 8038
Old 8th February 2005, 12:54 PM   #9
jackinnj's Avatar
Per-Anders,
Correct ?
if you don't know anything about the transformer just use a signal generator at 1kHz -- any old voltage will do providing your DVM is up to measuring -- most DVM's will read sine waves acurately to at least 1kHz -- at this frequency the generator will see a relatively high impedance so it won't be overloaded -- I used this method for years with an old Heathkit generator (now modified for 0.001% THD) . It really works.
Old 8th February 2005, 03:58 PM   #10
Per-Anders,
You are very kind.
Everything cleared.
Bye
Ari
The Xreg Voltage Stabilizer rjm Power Supplies 6 2nd February 2010 08:21 AM
D.I.Y car Voltage Stabilizer aka V.s ufo Everything Else 8 7th November 2009 09:47 AM
220V Voltage Stabilizer for home theter yusuf Power Supplies 12 5th April 2007 05:18 AM
Sziklai emitter follower as voltage stabilizer hjelm Solid State 23 25th May 2004 04:09 PM
about the shorted ring (flux stabilizer ring) haggy Multi-Way 3 4th January 2002 02:04 AM
Page generated in 0.13160 seconds (76.27% PHP - 23.73% MySQL) with 11 queries
