Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Music transient lengths?
Old 23rd January 2005, 05:52 PM   #1
breez is offline breez  Finland
Question Music transient lengths?
Hi
I wonder how long transients can be found in normal music?
Often amplifiers have peak power measured with a 20ms burst, but I have a feeling that 20ms is too short and I could use the info on choosing a PS trafo and caps in my chipamp (eg. whether to concentrate more on RMS power or peak power).
Old 25th January 2005, 06:06 AM   #2
Enzo is offline Enzo  United States
Let's say you had a clean peak at 100Hz. each cycle being a hyndredth of a second. That means the whole cycle is 10ms long or 5ms on each polarity. But that is the width of the pulse at its base. SInce you are woried about current, you pick a point further up the waveform, which will be narrower. But even at square waves, that is alternating 5ms peaks. If my math works, you need to go down to 25Hz to get that 20ms per peak. And I doiubt you will eb amplifying 25Hz squares.
CHances are your peaks will be at the bottom end, so do some calculations. COnsidering which portions of the waveform will be taxing the amp.
Music transient lengths?Hide this!Advertise here!
Port lengths: which measurement? rajivs Multi-Way 11 30th July 2009 04:55 PM
Wiring Speakers with Very Different Lengths hankallan Multi-Way 11 5th June 2007 11:59 PM
Building OB (right now) need help with side lengths davidallancole Full Range 5 9th April 2007 04:56 PM
How important are internal wire lengths for a GC? matt_uk Chip Amps 11 4th January 2004 10:23 AM
Speaker Cable Lengths? FrankRoss Everything Else 5 15th December 2001 01:46 AM
