Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd January 2005, 12:22 PM   #1
Circlotron's Avatar
Default MP3 encoding makes marginal recordings sound better?
Yesterday I listened to a 128kpbs MP3 file someone had made that was recorded from a reel to reel tape of a vinyl disc. The tape-to-disc part was done way back in 1972. What immediately struck me though was the clarity and lack of irritating distortions that were common in run-of-the-mill pressings back in those days. I'm quite old enough to remember them.
Then I got to thinking, with all the processing that goes into making an MP3 file, how it can discard background sounds that your ear may not notice very much, perhaps it was also discarding the nasty sounding bits of the recording as well. Just a theory.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 22nd January 2005, 12:40 PM   #2
analog_sa's Avatar
A more plausible explanation may be the shrinkage of your personal perceived bandwidth Who says old age does not have its advantages?
I also seem to notice the quality of tweeters over the last 20 years going down the drain.
Old 22nd January 2005, 03:09 PM   #3
Mr Evil is offline Mr Evil  United Kingdom
I have thought about MP3 before, and came to the conclusion that since it has a very distinctive sound, like vinyl, that some people are giong to like it. In fact I am very confident that the current generation is going to end up feeling very attached to the sound, just as there are those that are very attached to vinyl, or tubes, or whatever other sound (undoubtedly leading to horrendous flamewars about how the most modern compression methods suck the life out of music or somesuch nonsense!). I sometimes find myself almost enjoying the watery sound of MP3s.
Old 23rd January 2005, 12:14 AM   #4
thomas997's Avatar
Possibly some annoying high frequencies are being cut out?
Also when one frequency peaks it cuts out the other ones..
Info here: http://stuffo.howstuffworks.com/mp31.htm
Old 2nd February 2005, 05:47 PM   #5
dreamer is offline dreamer  Hong Kong
Send a message via ICQ to dreamer
Music from a MP3 decoder sound better may have the following reasons.
1. MP3 encoder removed those frequency spectrum below
the threshold due to masking effect. i.e. Music from the MP3
decoder does not contain the full spectrum or you can say,
less complex to process.
2. Most of the low cost amplifier are bad in IM or TIM distortion.
As some of the frequency is removed, the effect of IM or TIM
will be lower and the sound may become better in quality for
listen.
Old 6th February 2005, 07:28 AM   #6
sivan_and's Avatar
Send a message via Yahoo to sivan_and
By using encoders like MP3Doctor one can really play with music even add some effects like ambiance, 3D surround..etc
SivanandBalan
Old 6th February 2005, 06:00 PM   #7
Frank Berry's Avatar
"Then I got to thinking, with all the processing that goes into making an MP3 file, how it can discard background sounds that your ear may not notice very much, perhaps it was also discarding the nasty sounding bits of the recording as well. Just a theory."
Circlotron,
I believe your theory to be correct. I've noticed the same thing when making mp3 copies of somewhat noisy analog tapes.
Frank
Old 7th February 2005, 03:25 AM   #8
sivan_and's Avatar
By adj equaliser, Good scratch and rumble filtering can be achieved must for converting vinly LP's into MP3..
SivanandBalan
Old 8th February 2005, 01:36 AM   #9
simon5 is offline simon5  Canada
Most cheap mp3 encoding programs don't use Lame.
If you don't use Lame, everything over 16 kHz is cut off with a very fast rolloff.
Especially at low bitrates like 128 kbits/sec, even with Lame, you will lose some of the treble, which is good with bad recordings, because it will attenuate high frequency artifacts by the way.
If you use Lame, VBR, at 320 kbits/sec, you will still hear high frequency artifacts without any problems !
DIYaudio for President !
Why most recordings sound like crap.... Jocko Homo Music 156 15th January 2007 03:50 PM
Why do many recordings sound so bad? keyser Music 7 24th April 2005 04:22 AM
With one makes more sound! destroyer X Solid State 43 8th June 2004 12:11 PM
What makes different speakers sound ... different? cuallito Multi-Way 16 14th April 2004 02:13 AM
What makes the most sound improvement? BlackDog Chip Amps 19 29th February 2004 08:56 PM
Page generated in 0.13866 seconds (79.72% PHP - 20.28% MySQL) with 10 queries
