| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Could you reccommend a site where I might find info on converting 220V
> equipment to 120V. I've got a British amp and would like to convert it > for use here (US). Thanks in advance Mike mmoore@uclink4.berkeley.edu |
#2 |
I would check Radio Shack believe it or not.
All you need is a simple step down transformer. Pixie |
#3 |
Yeah I think the easiest to do is use a 220 to 110 transformer. Even better would be to change the transformer inside the amp but it could be not so practicle.
#4 |
Using a 220v to 110v transformer *will* work, but normally the kind selled by Radio Shack is not the best quality... besides, you'll have two input transformers heating. I'd really try to change the internal power supply transformer to one rated for the same output voltage (you can measure it) and 110v input. It'll run much cooler.
#5 |
Have you checked the mains transformer of the amp? It may be possible for the transformer to have a dual primary that can be wired for 220 or 110. You would have to get inside and trace the primary windings, or contact the manufacturer for instructions.
G. Cherhit |
| fpb 300 voltage conversion from us to uk? | patbarrydub | Solid State | 5 | 5th December 2011 01:00 PM |
| Electrocompaniet AW 120 voltage conversion | Slavaua | Solid State | 12 | 5th March 2009 12:00 PM |
| Voltage conversion; need help please | steve96822 | Power Supplies | 12 | 8th September 2006 07:45 AM |
| Voltage conversion? | mmx_2 | Solid State | 0 | 28th December 2004 12:25 PM |
| Voltage conversion: US to UK? | diaspora | Parts | 3 | 3rd May 2004 08:09 PM |
