VU Meter
Im looking to add a VU meter to this project im working on. Its a simple audio demonstration project my professor wants to use to demonstrate some of the things we do in our major. It will run off of 2 batteries with a switching regulator to output +12V. It will then go through one of 3 filters LP, BP or HP, then a 10W amplifier. The only thing im confused on is how to add a VU meter to this project. Suggestions?
Kurt
Are you looking for a meter to make actual measurements with?
Volume Units are tightly designed for both attack and decay response of the display. Originally a Western Electric galvanometer mechanism and later as displayed in LED lights.
"0 Vu" also is also defined by specific reference levels (-10, +4 and +8 dB). Each has a definition or how the meter is bridged across an audio load to make its appropriate measurement.
A reference power level shown on a VU METER. Although 0 VU is shown on a VU meter as the point of 100% MODULATION, it is not identical to the reference called zero level, which in fact refers to -4 dB or -4 VU on the meter.
Zero level is the reference level obtained with a 1000 Hz signal and 1 milliwatt of power in a line or circuit of 600 ohms resistance (a 600-ohm line). The corresponding voltage level is 0.773 volts. This level is sometimes called 0 dbm. Other levels may be described in reference to it; for instance, 0 VU is +4 dbm and represents a voltage level of 1.228 volts.
Compare: DECIBEL, THRESHOLD OF HEARING.
http://www2.sfu.ca/sonic-studio/handbook/Zero_Level_VU.html
other good articles on proper Vu metering techniques can be found at:
http://www.benchmarkmedia.com/meters/default.asp
and
http://www.dorrough.com/dorrough/about_us/about_vision.html
(I once got a trouble ticket saying that the "View Meter" was boken on the audio mixer)
